JackShine
- Nov 13, 2014
Hi
I want to move away from booting from USB sticks, I have 2 sandisks mirrored. They seem to be the only problem I have with my machine, doesn’t matter if I buy new ones, they don’t behave.
Anyway im moving to a single SSD boot drive.
I have 10 X 4TB WD reds, 6 are controlled by the Supermicro MB SATA s the other 4 by an HBA LSI Internal SAS SATA 9211-8i.
My question is, should I connect the SSD drive to the MB SATAs (which means moving all the connections of all my drives), or just connect to the HBA?
Of course ive installed the latest O/S to my SSD and saved my config files.
Thanks
Thanks
