Hardware SuperMicro vs Chenbro + ASRock
tbaror
Hi All,
I have two different hardware type with almost same spec , i would like to have your opinion which is better choice?
Please advice
Thanks
SuperMicro
Chassis
: SuperMicro 4U Storage Server CSE-846BE1C-R1K28B
MB:Supermicro MBD-X10SRH-CLN4F Integrated -4x RJ45 Gigabit Ethernet LAN ports
HBA:SAS3 (12Gbps) via LSI 3008
Memory:8x DDR4-32GB-2133MHZ-LP ECC LRDIMM
Cpu :Haswell-EP 4C E5-1620V3 3.5G 10M + 4U SNK
Network:Mellanox ConnectX®-3 EN network interface card,10GbE, dual-port SFP+,PCIe3.0 x8 8GT/s
Disks:16x Seagate 3.5" 2TB SATA 6Gb/s 7.2K RPM 128M
SSD:2x Samsung SM843Tn, 480GB,SATA 6Gb/s, MLC, 2.5"
OS USB:1x DOK SanDisk USB 3.0 64GB
Chenbro
Chassis: Chenbro Rackmount RM41824 24
MB: ASRockRack EPC612D8
Memory:8x Kingston KVR21R15D4/32 32GB LRDIMM
Network:intel Ethernet Server Bypass Adapter X520-SR2
Disks:16x Seagate 3.5" 2TB SATA 6Gb/s 7.2K RPM 128M ST200NM0033
tbaror
Anyone?
Hi All,
Please advice
Thanks
SuperMicro
Chassis
Chenbro
Mirfster
Question on the "SuperMicro" build... the case you chose has "4x mini-SAS HD connectors" for the backplane, are you thinking of just using the two SAS connectors built onto the Motherboard for now to try and use the 16 drives? I think you may need to add another HBA to get two extra connections to the backplane (or at least one more).
Also, USB 3.0 is not really supported too well with FreeNas 9.x; so you may want to check on this..
