Build with FreeNAS with supermicro Hardware
Luis Seixas
Build with FreeNAS
I see the model of Supermicro Hardware, then I think the following configuration:
SuperStorage Server 2028R-E1CR48N (Complete System Only)
(2x)Processador BDW-EP 8C E5-2620V4 2.1G 20M 8GT QPI
(8x) 32GB DDR4-2400 2RX4 ECC REG RoHS(totalizando 256GB)
(42x) Disco Seagate 2.5 1TB SATA 6Gb/s 7.2K RPM 128M, 512N (Avenger)
(6x) Disco SSD 2.5 1TB
(2x) Fonte redundante -1600W Redundant Power Supplies with PMBus
Because I need 48TB data storage.
How I can to know about hardware compatibility for this model to run on FreeNAS OS.
If you need 48TB of data storage, you're not there yet even before you add redundancy. Further, ZFS works best when the filesystem has plenty of empty space. You're going to need to increase the drive size or add an external storage tray. Possibly both.
That aside, Supermicro hardware is well-supported. If you're using their recommended ECC RAM, you should be in good shape.
Cheers,
Matt
