macosxgeek
- Jul 20, 2018
I'm running FreeNAS server which basically boots from USB stick. Here are some details on the server itself:
FreeBSD <my_hostname_here> 9.3-RELEASE-p13 FreeBSD 9.3-RELEASE-p13 #4 r281084+c7bb047: Wed Apr 15 15:03:01 PDT 2015 root@build3.ixsystems.com:/tank/home/jkh/build/FN/objs/os-base/amd64/tank/home/jkh/build/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
CPU: Intel(R) Xeon(R) CPU E5-2603 v3 @ 1.60GHz (1600.03-MHz K8-class CPU)
FreeBSD/SMP: Multiprocessor System Detected: 12 CPUs
hw.physmem: 34222850048 (32GB)
Basically system is working fine for most of the time (it reboots occasionally without a reason - but I guess that's related to the USB stick being corrupted).
Can I ask what's the best way for replacing the USB stick to a new one without loosing any data? Also I wanted to put the latest STABLE FreeNAS on the new USB stick - but I guess that won't be a big problem..
Any help would be appreciated.
Best regards
macosxgeek
[root@mynas] ~# zpool status pool: freenas-boot state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0h1m with 8 errors on Fri May 4 03:46:10 2018 config: NAME STATE READ WRITE CKSUM freenas-boot DEGRADED 0 0 0 gptid/0a2caa32-ed03-11e4-a358-0cc47a34217e DEGRADED 0 0 0 too many errors errors: 9 data errors, use '-v' for a list pool: raid10 state: ONLINE scan: scrub repaired 0 in 213h56m with 0 errors on Mon Jul 9 21:56:39 2018 config: NAME STATE READ WRITE CKSUM raid10 ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/764d8d5d-ed0a-11e4-8e51-0cc47a34217e ONLINE 0 0 0 gptid/76c063b4-ed0a-11e4-8e51-0cc47a34217e ONLINE 0 0 0 mirror-1 ONLINE 0 0 0 gptid/772993dc-ed0a-11e4-8e51-0cc47a34217e ONLINE 0 0 0 gptid/77a3311a-ed0a-11e4-8e51-0cc47a34217e ONLINE 0 0 0 mirror-2 ONLINE 0 0 0 gptid/7813e5d8-ed0a-11e4-8e51-0cc47a34217e ONLINE 0 0 0 gptid/a2ce2508-954b-11e7-a444-0cc47a34217e ONLINE 0 0 0 mirror-3 ONLINE 0 0 0 gptid/78ee89a5-ed0a-11e4-8e51-0cc47a34217e ONLINE 0 0 0 gptid/cd459747-9544-11e7-a444-0cc47a34217e ONLINE 0 0 0 errors: No known data errors
Best regards
macosxgeek
