"Replaced" boot device shows up as da3 instead of gptid/blahblah
depasseg
FreeNAS Replicant
On my 9.3 (FreeNAS-9.3-STABLE-201602031011) I just replaced a USB boot device (it was one of a mirror). I used the GUI Boot->Status->select failing device and click replace. Now I see that the device isn't listed like the rest of my drives (using the GPTID). Instead, it's using the da3 name.
Should I be concerned? Is this OK? Looking for advice.
  pool: freenas-boot
state: ONLINE
  scan: resilvered 7.15G in 1h2m with 0 errors on Sun Mar 27 19:18:06 2016
        freenas-boot                                    ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            da3p2                                       ONLINE       0     0     0
            gptid/1caf62bd-c83f-11e4-ab84-001f33eaf869  ONLINE       0     0     0
errors: No known data errors
[root@freenas2] ~#
I'd file a bug report, just to be sure.
Some of the boot device handling logic seems to have suffered with the transition from FreeBSD 9 to FreeBSD 10.
depasseg
FreeNAS Replicant
Hmm, I'll have to make a mental note of this. It's certainly unintuitive.
