I went out and bought a 600E after seeing it was compatible & working (+cheap) with FreeNAS. I plugged it in and set it up with the standard usbhid driver and port auto and it worked! I pulled the plug, got a couple of beeps and the system shut off gracefully. Woho :D
Then I upgraded to FreeNAS 8...
System Information
ups settings:
Atm all I can get from the UPS is this:
*plug in or boot up with the UPS plugged in*
Anyone know where to begin?
edit: if I boot up with the UPS plugged in and then restart the UPS service after boot it will stop disconnecting
System Information
Hostname filserver.local
FreeNAS Build FreeNAS-8.0.2-RELEASE-amd64 (8288)
Platform AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Memory 4080MB
System Time Sun Nov 13 23:12:54 2011
Uptime 11:12PM up 8 mins, 0 users
Load Average 0.15, 0.16, 0.13
OS Version FreeBSD 8.2-RELEASE-p3
ups settings:
Service: enabled
Driver: usbhid-ups
Port: /dev/ugen0.2
Shutdown mode: UPS goes on battery
Shutdown timer: 30
With the UPS service enabled with "shut off if UPS goes on battery" the FreeNAS box will do random shutdowns.ugen0.2: <CPS> at usbus0
ugen0.2: <CPS> at usbus0 (disconnected)
Nov 13 23:07:20 filserver upsd[3008]: mainloop: Interrupted system call
Nov 13 23:07:20 filserver upsmon[3028]: upsmon parent: read
