fajung
- Mar 11, 2018
Hello, yesterday I bought an a Lyonn CTB-800 UPS, to prevent any damages when the energy is cut off, which is quite often around here, especially during summer seasons. well, did a litle researh which ups I could buy, and found the ups supported list http://networkupstools.org/stable-hcl.html and search and I found that in here I could get the Lyonn CTB-800V, but today I plugged the usb to my FreeNas PC, set the configuration in the Service > UPS, and when I press Start Now, I get this msg:
here is the "dmesg | grep ugen" command:
the SAI/UPS configuration:
in the manual say:
Power supply: Sentey 630w
Motherboard: ASUS Prime 320k-M
Proccesor: AMD Apu A10 9700k bridge
RAM: ballistix sports DDR4 8gb
HDD: WD Red 2TB
Flashdrive: SanDisk cruze ultra fit 3.0 16GB
OS: FreeNAS-11.1-U2
and so and so until I change any setting on the configuration.[date] freenas upsmon [7865] : UPS [ups]: Connect faliure: Connection faliure: Connection refused
ugen1.1: <0x1022 XHCI root HUB> at usbus1 ugen0.1: <0x1022 XHCI root HUB> at usbus0 ugen0.2: <SanDisk Ultra Fit> at usbus0 ugen0.3: <INNO TECH USB to Serial> at usbus0 ugen0.4: <Logitech USB Receiver> at usbus0
UPS Mode: Master
Indentifier: ups
Driver: Lyonn ups 2 CTB-800V (nutdrv_qx)
port: /dev/ugen0.3
Auxiliary parameters (ups.conf): []
Auxiliary parameters (upsd.conf):[]
Description: UPS Lyonn CTB-800V
Shutdown mode: Ups goes on batery
Shutdown timer: 30
Shutdown Command: /sbin/shutdown -p now
No Communication Warning Time: []
Monitor User: administrator
Monitor Password: administrator
Extra users (upsd.users): []
Remote Monitor:
Send Email Status Updates: []
Power Off UPS:![]()
in the manual say:
user name and password in the software management:
User name: administrator
HDD: WD Red 2TB
OS: FreeNAS-11.1-U2
