ups - Duplicate driver instance detected! Terminating other driver!
ethereal
i've had a ups for a month now and when i boot the system i get this -
network ups tools - ups driver controller 2.7.3
network ups tools - Generic HID driver 0.39 (2.7.3)
USB communication driver 0.32
i run a script to change the maxage to avoid the data getting stale. when i run the script i get this -
on a daily basis i get -
Jan 7 20:47:07 freenas usbhid-ups[3837]: Got disconnected by another driver: Device busy
i think this problem is because of the duplicate driver instance - can somebody help me find out why i have two instances running and stop the problem ?
keep it simple please i am a moron (not certified anymore i forgot to go to the meetings)
SweetAndLow
Sweet'NASty
When you run this script what does it do? Probably best to shutdown nut, modify upsd.conf then start nut.
ethereal
when i boot the server this is in the console -
but i don't think it terminates because there is still a duplicate every time i run the script. and which i think leads to the few times a day -
m0nkey_
I'd have to question why you're using a script at all to interact with a service. If you have additional parameters for NUT, you should put them in the auxiliary parameters box in the GUI.
ethereal
maxage needs to go in to upsd.conf
auxiliary parameters box in the GUI is for ups.conf
rogerh
Could be a UPS bug, or a NUT driver bug, or just possibly a FreeNAS bug (including the non-driver parts of NUT). But not many people seem to have noticed it so the particular driver or UPS seems likelier. I'd try on a NUT forum (Google will know), but if they have no clue I'd suggest report it as a bug through the FreeNAS GUI. If you do the latter a) you have to register on the FreeNAS bug system before you start, and b) it is a good idea to let the GUI upload a debug file (will take ages). And please let us know the bug number if you do!
joeschmuck
Old Man
Duplicate Threads? I think you posted this in two places, not very cool for certain. Which one do you want me to delete or lock?
ethereal
i tried to get support - and then i thought i had opened a bug report. (but it was only in the bug reporting forum) sorry.
i have created a bug report now.
you can delete any post you like
Ah, you missed the joke opportunity!
"Duplicate thread detected! Terminating other thread!"
joeschmuck
Old Man
