I am trying to get the UPS service running. My UPS worked great with Freenas 7, so I would think my APC back ups es 725 should still be supported.
I am running 8.2-r8971-amd64. IS there a guide to go by to get this service working?
When I try to turn on the UPS service, I get the following:
Dec 11 12:28:05 bilnas notifier[1981]: Executing: /usr/sbin/service ix-ups quietstart
Dec 11 12:28:05 bilnas notifier[1981]: Executing: /usr/sbin/service nut restart
Dec 11 12:28:05 bilnas notifier: nut not running? (check /var/db/nut/upsd.pid).
Dec 11 12:28:06 bilnas notifier: Network UPS Tools - Generic HID driver 0.35 (2.6.1)
Dec 11 12:28:06 bilnas notifier: USB communication driver 0.31
Dec 11 12:28:06 bilnas notifier: No matching HID UPS found
Dec 11 12:28:06 bilnas notifier: Driver failed to start (exit status=1)
Dec 11 12:28:06 bilnas notifier: Network UPS Tools - UPS driver controller 2.6.1
Dec 11 12:28:06 bilnas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Dec 11 12:28:06 bilnas notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Dec 11 12:28:06 bilnas notifier[1981]: Executing: /usr/sbin/service nut_upsmon restart
Dec 11 12:28:06 bilnas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Dec 11 12:28:06 bilnas notifier: Starting nut_upsmon.
Dec 11 12:28:06 bilnas notifier: UPS: ups (master) (power value 1)
Dec 11 12:28:06 bilnas notifier[1981]: Executing: /usr/sbin/service nut_upslog restart
Dec 11 12:28:06 bilnas upsmon[6027]: UPS [ups]: connect failed: Connection failure: Connection refused
Dec 11 12:28:06 bilnas upsmon[6027]: Communications with UPS ups lost
Dec 11 12:28:06 bilnas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid).
Dec 11 12:28:06 bilnas notifier: Starting nut_upslog.
Dec 11 12:28:06 bilnas notifier: Warning: initial connect failed: Connection failure: Connection refused
Dec 11 12:28:06 bilnas notifier[1981]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Dec 11 12:28:06 bilnas notifier[1981]: Executing: /usr/sbin/service nut_upslog stop
Dec 11 12:28:06 bilnas notifier: Stopping nut_upslog.
Dec 11 12:28:06 bilnas notifier[1981]: Executing: /usr/sbin/service nut_upsmon stop
Dec 11 12:28:07 bilnas notifier: Stopping nut_upsmon.
Dec 11 12:28:07 bilnas upsmon[6026]: upsmon parent: read
Dec 11 12:28:07 bilnas notifier[1981]: Executing: /usr/sbin/service nut stop
Dec 11 12:28:07 bilnas notifier: Will not 'stop' nut because nut_enable is NO.
Dec 11 12:28:07 bilnas notifier[1981]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
