I've recently bought a re-branded UPS and tried to see if FreeNAS will support it.
It's basically using ViewPower UPS UI management system so I took a wild guess (based on other posts here) and tried to define with 'nutdrv_qx' drive.
This is how it's defined on FreeNAS UI:
http://i.imgur.com/WXk6QGS.png
Upon turning on the UPS service:
So far so good ? Thats what I thought (experts might detect an error in that output maybe ?).
Tried to plug the UPS power cable to the wall and debug the footer 'console messages':
And it's off. cool ! right ?
[1] 1st Problem - Testing UPS shut down machine unable to recognize the UPS upon start up:
Problem is, after I plugged the UPS back to power, and started the FreeNAS machine I get messages that the UPS is unable to connect:
Control Services -> turned UPS Off and On again, and we were back online with the UPS:
again upsc ups@localhost and connection shows up perfectly as before, full info.
[2] 2nd Problem - Out of no where, 6 hours after UPS identified and connected to FreeNAS I get 'UPS driver' messages:
Following another post here, I've executed the following commands to debug:
Switch off the UPS service in the GUI Run: /usr/local/libexec/nut/nutdrv_qx -a ups -DDD:
Next /usr/local/libexec/nut/upsdrvctl start:
and upsd -DDD:
Any help regarding these 2 issues will be highly appreciated !
Thanks
P.S (if it's any help):
Running FreeNAS-9.2.1.8-RELEASE-x64 on Intel(R) Pentium(R) CPU G3240 @ 3.10GHz with 8gb ram.
[SOMEUSER@freenas] /% upsc ups@localhost battery.charge: 100 battery.voltage: 13.50 battery.voltage.high: 13.00 battery.voltage.low: 10.40 battery.voltage.nominal: 12.0 device.type: ups driver.flag.novendor: enabled driver.name: nutdrv_qx driver.parameter.pollfreq: 30 driver.parameter.pollinterval: 10 driver.parameter.port: auto driver.version: 2.7.1 driver.version.data: Mustek 0.01 driver.version.internal: 0.01 input.current.nominal: 3.0 input.frequency: 50.0 input.frequency.nominal: 50 input.voltage: 232.8 input.voltage.fault: 234.9 input.voltage.nominal: 230 output.voltage: 234.9 ups.beeper.status: enabled ups.delay.shutdown: 30 ups.delay.start: 180 ups.load: 2 ups.productid: 5161 ups.status: OL ups.type: offline / line interactive ups.vendorid: 0665
Oct 11 16:18:38 freenas upsmon[17348]: UPS ups on battery Oct 11 16:19:08 freenas upssched-cmd: issuing shutdown Oct 11 16:19:08 freenas upsmon[17348]: Executing automatic power-fail shutdown Oct 11 16:19:08 freenas upsmon[17348]: Auto logout and shutdown proceeding Oct 11 16:19:38 freenas shutdown: power-down by root:
Oct 11 16:22:54 freenas upsmon[2417]: UPS [ups]: connect failed: Connection failure: Connection refused Oct 11 16:22:54 freenas upsmon[2417]: Communications with UPS ups lost Oct 11 16:22:59 freenas upsmon[2417]: UPS [ups]: connect failed: Connection failure: Connection refused Oct 11 16:22:59 freenas upsmon[2417]: UPS ups is unavailable Oct 11 16:24:19 freenas upsmon[2417]: UPS [ups]: connect failed: Connection failure: Connection refused Oct 11 16:24:49 freenas last message repeated 6 times Oct 11 16:26:49 freenas last message repeated 24 times Oct 11 16:28:04 freenas last message repeated 15 times Oct 11 16:28:04 freenas upsmon[2417]: UPS ups is unavailable Oct 11 16:28:09 freenas upsmon[2417]: UPS [ups]: connect failed: Connection failure: Connection refused etc...
Oct 11 16:32:03 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Oct 11 16:32:03 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Oct 11 16:32:03 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid). Oct 11 16:32:03 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Oct 11 16:32:03 freenas root: Unknown USB device: vendor 0x0665 product 0x5161 bus uhub2 Oct 11 16:32:04 freenas notifier: Using protocol: Mustek 0.01 Oct 11 16:32:04 freenas notifier: No values for battery high/low voltages Oct 11 16:32:04 freenas notifier: Using 'guesstimation' (low: 10.400000, high: 13.000000)! Oct 11 16:32:04 freenas notifier: Battery runtime will not be calculated (runtimecal not set) Oct 11 16:32:05 freenas notifier: Network UPS Tools - UPS driver controller 2.7.1 Oct 11 16:32:05 freenas notifier: Starting nut. Oct 11 16:32:05 freenas notifier: fopen /var/db/nut/upsd.pid: No such file or directory Oct 11 16:32:05 freenas notifier: listening on 127.0.0.1 port 3493 Oct 11 16:32:05 freenas notifier: Connected to UPS [ups]: nutdrv_qx-ups Oct 11 16:32:05 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Oct 11 16:32:05 freenas notifier: Starting nut_upsmon. Oct 11 16:32:05 freenas notifier: kill: No such process Oct 11 16:32:05 freenas notifier: UPS: ups (master) (power value 1) Oct 11 16:32:05 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid). Oct 11 16:32:05 freenas notifier: Starting nut_upslog.
Oct 11 22:24:02 freenas nutdrv_qx[16013]: Permissions problem: Input/output error Oct 11 22:24:02 freenas upsd[16015]: Can't connect to UPS [ups] (nutdrv_qx-ups): No such file or directory Oct 11 22:24:04 freenas upsmon[16040]: Poll UPS [ups] failed - Driver not connected Oct 11 22:24:04 freenas upsmon[16040]: Communications with UPS ups lost Oct 11 22:24:09 freenas upsmon[16040]: Poll UPS [ups] failed - Driver not connected Oct 11 22:24:44 freenas last message repeated 7 times Oct 11 22:26:49 freenas last message repeated 25 times
[SOMEUSER@freenas] /# cat /etc/local/nut/ups.conf
[ups]
driver = nutdrv_qx
port = /dev/ugen0.4
desc = "UPS"
novendor
port=auto
pollinterval=10Switch off the UPS service in the GUI Run: /usr/local/libexec/nut/nutdrv_qx -a ups -DDD:
[SOMEUSER@freenas] /# /usr/local/libexec/nut/nutdrv_qx -a ups -DDD Network UPS Tools - Generic Q* USB/Serial driver 0.01 (2.7.1) USB communication driver 0.32 0.000000 debug level is '3' 0.004735 upsdrv_initups... 0.009513 Checking device (05DC/A209) (/dev/usb//dev/ugen1.4) 0.027528 - VendorID: 05dc 0.027740 - ProductID: a209 0.027784 - Manufacturer: Lexar 0.027825 - Product: USB Flash Drive 0.027865 - Serial Number: BBFD46CA080A8A449FA3 0.027905 - Bus: /dev/usb 0.027912 Trying to match device 0.027989 Device does not match - skipping 0.028291 Checking device (0665/5161) (/dev/usb//dev/ugen0.4) 0.029974 - VendorID: 0665 0.030022 - ProductID: 5161 0.030062 - Manufacturer: unknown 0.030103 - Product: unknown 0.030109 - Serial Number: unknown 0.030150 - Bus: /dev/usb 0.030190 Trying to match device 0.030232 Device matches 0.061155 send: QGS 0.205178 read: QGS 0.205348 qx_process_answer: short reply (input.voltage) 0.206404 send: QGS 0.350115 read: QGS 0.350202 qx_process_answer: short reply (input.voltage) 0.350955 send: QGS 0.495090 read: QGS 0.495178 qx_process_answer: short reply (input.voltage) 0.496142 send: QS 0.813007 read: (234.9 234.9 234.9 002 50.0 13.7 --.- 00001001 0.813347 Using protocol: Mustek 0.01 0.813515 blazer_initups: skipping device.mfr 0.813684 blazer_initups: skipping device.model 0.813769 blazer_initups: skipping ups.firmware 0.813985 upsdrv_initinfo... 0.814737 send: QS 1.131015 read: (234.9 234.9 234.9 002 50.0 13.7 --.- 00001001 1.131688 ups_infoval_set: non numerical value [ups.temperature: --.-] 1.132920 send: F 1.340034 read: #230.0 003 12.00 50.0 1.340841 No values for battery high/low voltages 1.340967 Using 'guesstimation' (low: 10.400000, high: 13.000000)! 1.341050 Battery runtime will not be calculated (runtimecal not set) 1.341259 upsdrv_updateinfo... 1.341348 Quick update... 1.342400 send: QS 1.659058 read: (234.9 234.9 234.9 002 50.0 13.7 --.- 00001001 1.660571 dstate_init: sock /var/db/nut/nutdrv_qx-ups open on fd 6 1.660744 upsdrv_updateinfo... 1.660789 Quick update... 1.661591 send: QS 1.978029 read: (237.0 234.9 234.9 002 50.0 13.7 --.- 00001001 11.661718 upsdrv_updateinfo... 11.661886 Quick update... 11.662851 send: QS 11.978821 read: (234.9 232.8 234.9 002 50.0 13.7 --.- 00001001 etc...
[SOMEUSER@freenas] /# /usr/local/libexec/nut/upsdrvctl start Network UPS Tools - UPS driver controller 2.7.1 Network UPS Tools - Generic Q* USB/Serial driver 0.01 (2.7.1) USB communication driver 0.32 Using protocol: Mustek 0.01 No values for battery high/low voltages Using 'guesstimation' (low: 10.400000, high: 13.000000)! Battery runtime will not be calculated (runtimecal not set)
and upsd -DDD:
[SOMEUSER@freenas] /# upsd -DDD Network UPS Tools upsd 2.7.1 0.000000 fopen /var/db/nut/upsd.pid: No such file or directory 0.003680 listen_add: added 127.0.0.1:3493 0.006383 setuptcp: try to bind to 127.0.0.1 port 3493 0.007101 listening on 127.0.0.1 port 3493 0.010021 Connected to UPS [ups]: nutdrv_qx-ups 0.019816 user_add_action: adding 'login' for upsmon 0.020153 user_add_action: adding 'master' for upsmon 0.020368 user_add_action: adding 'fsd' for upsmon 0.020702 mainloop: polling 2 filedescriptors 0.021592 mainloop: polling 2 filedescriptors 0.022737 mainloop: polling 2 filedescriptors 0.023749 UPS [ups]: dump is done 0.024046 mainloop: polling 2 filedescriptors 2.025156 mainloop: no data available 2.025666 mainloop: polling 2 filedescriptors 4.026161 mainloop: no data available 4.026706 mainloop: polling 2 filedescriptors 6.027372 mainloop: no data available 6.028683 Pinging UPS [ups] 6.029824 mainloop: polling 2 filedescriptors 6.030583 Got PONG from UPS [ups] 6.031175 mainloop: polling 2 filedescriptors 8.032259 mainloop: no data available 8.033443 mainloop: polling 2 filedescriptors 10.034155 mainloop: no data available 10.034701 mainloop: polling 2 filedescriptors 12.035179 mainloop: no data available 12.035693 Pinging UPS [ups] 12.036155 mainloop: polling 2 filedescriptors 12.036489 Got PONG from UPS [ups] 12.036705 mainloop: polling 2 filedescriptors 14.037153 mainloop: no data available 14.037703 mainloop: polling 2 filedescriptors 16.038307 mainloop: no data available 16.039534 mainloop: polling 2 filedescriptors 18.041389 mainloop: no data available 18.042615 Pinging UPS [ups] 18.043715 mainloop: polling 2 filedescriptors 18.044475 Got PONG from UPS [ups] 18.044982 mainloop: polling 2 filedescriptors 20.046167 mainloop: no data available 20.046422 mainloop: polling 2 filedescriptors
Thanks
