I'm undertaking the overdue task of replacing my
6 x 4TB WD Red WD40EFRX-68W (9 years old!) RAIDZ2 pool - used for windows shares
with new
4 x Seagate ST16000NM004J Exos Enterprise (X18) 16TB SAS Hard Drive in RAIDZ2
The Server does not have space for 10 drives & network switch only has two 10GB ports - both in use
I've a spare PC so have have tested the drives using surface reinitialisation of HD Sentinel (38Hrs) and my plan is as follows
(I have back ups of the data on mirrored external drives NTFS)
Using Spare PC
Then on current Server
with new
Using Spare PC
- Use spare SSD and install TrueNAS Clean
- Create a Pool of the 4 EXOS drives using the same Name case in mixed case (current pool is
- Connect a backup drive and copy the data to the new pool
- Share the pool and confirm access permissions
- export pool
- shutdown
- Disable init tasks the runs the SiliconDust PVR software
- Export old pool
- Swap in New Drives
- Boot
- Import pool
- Reboot
- Confirm pool working / check shares
- Re-enable init task
- Reboot
