I currently have a reliable system running 10 4TB WD RED in 2 VDEV with GELI (Legacy) encryption on TrueNAS 13.
Recently, I had to perform a disk replacement on a young disk (less than 5 years, I think).
My pool is currently showing the following statistics:
4 of them have reach 9+ year Power-on Time.
3 of them have reach 6+ year Power-on Time.
1 of them have reach 5+ year Power-on Time.
2 of them are below 5 year Power-on Time.
So to summarize, the pool is getting a bit old.
I don't really see any benefit with replacing the disk with 4TB drives anymore as I am keeping an eye on as not to exceed 80% used space (currently at 75% read from Dashboard).
4TB WD RED aren't that affordable anymore.
I am thinking of making the move to EXOS X18 18TB drives with 7 disks in RAIDZ2.
This will buy me extra storage space with faster and newer disks (albeit switching from 2 VDEV to 1 VDEV).
One of the main concern I have is related to the encryption scheme.
I am currently using GELI encryption but I have been replicating the pool to a few pools based on the new encryption standard.
This has been a bit more tricky to maintain replication due to having to reload the replication (remote backup on local LAN) server with the remote passphrase and reallocate dataset structure. Personaly, I don't see the new encryption to be that appealing as it shows the dataset name in clear text.
Nevertheless, I am looking for advice. Should I creeate a new GELI encrypted pool (using FreeNAS) and migrate the data through replication or should I go with the new Pool/dataset structure so that I can benefit from the new encryption scheme.
I am using some VM's and a few iocage jails and as such, moving with the new encryption mechanism requires I changes how the pool/dataset structure is configured.
As much as I would like to use Key for the Pool and Passphrase on dataset, the new encryption mechanism makes management of Passphrase so difficult.
I haven't performed any replication on a system based on the new encryption. It is possible the passphrase issue will disappear when replicating to a remote system.
Any recommendation/feedbacks, would be much appreciated.
