Running TrueNAS-13.0-U5.3 CORE on two servers.
Server1 is originally a FreeNAS, regularly updated during the years and therefore now a TrueNAS.
I have been using GELI encryption on the disks since the time of FreeNAS.
Server2 is completely newly installed.
Using a pool that is Passphrase-encrypted on the root dataset "Data4" and the child datasets under "Data4" would inherit the encryption from the parent.
Datasets created under Data4 does inherit the encryption.
I'm moving all my data from Server1 to Server2, using a run-once Replication task.
When doing a test, Replication of Server1/Data1/Temporary to Server2/Data4/Temporary, the task will complete, but I got this message on Server2:
"The following datasets are not encrypted but are within an encrypted dataset: 'Data4/temporary' which is not supported behaviour and may lead to various issues."
I also have an locked padlock on that replicated dataset on Server2.
Any idea why the dataset "temporary" did not enherit the encryption from it's parent Data4?
Isn't it possbile to do a Replication this way, to an encrypted dataset?
