pious_greek
- Nov 28, 2017
Hi All, I was hoping someone with more experience could verify the following procedure is sound....
I would like to migrate from TrueNAS Core 13.0-U5.3 to TrueNAS Scale. I have made appropriate backups of all config, keys, geli keys, offline replication, etc. My current Pool ("Tank") has the legacy Geli encryption, so I gather this adds a few additional steps.
Goals:
Please let me know if there's an easier way or you see any flaws in the approach.
Goals:
- Remove the geli enycryption
- Restore data to a new pool as well as datasets that have the zfs encryption.
- upgrade core to scale
- Create a temporary backup NAS (Backup_NAS). The backup NAS Pool will be created with zfs encryption.
- Replicate the "Tank" pool to the backup NAS over local network. I will not use any encryption for the replication task.
- confirm replication task successful. use "fc" to compare the piped output of "dir /s" for each of the pools.
- Delete the old Geli encrypted Tank pool.
- Created a new zfs encyrpted Tank Pool.
- Create a new replication task to replicate the Backup_NAS pool back to the TANK pool.
- switch trains to truenas scale and upgrade via the gui.
