Brownz
- Sep 5, 2017
Im attempting to follow this guide to migrating from geli encryption and all is working so far. Then I get to actually copying my data across to new pool using the following commands:
I followed the same command that @winnielinnie has mentioned, although my filenames are slighlty different.
Not sure if this would cause issues, but I did deviate from the creation fo snapshots by creating one for each individual child dataset instead of the whole pool, mainly because iocage dataset is on same pool and received message saying 'cannot create snaptshot' for each iocage jails followed by 'no snapshots were created'.
zfs snap -r tank/media@migrate-20201209 zfs send -v -R tank/media@migrate-20201209 | zfs recv -v -d -R -x encryption new\ tank/store invalid option 'R'
- Not sure why my zfs command doesnt recognise this option...should I remove this option, is it neccessary?
- The iocage dataset worked fine...I think the receive command used the 'F' option instead of 'R', is this worth trying?
