Use netcat instead of SSH + monitor zfs send/receive
panz
I'm trying to manually zfs send/receive using nc instead of SSH (both servers are on a trusted network).
sending machine pool: tank
sending machine dataset: music
receiving machine pool: backup
So, my setup for the receiving server (IP 192.168.1.117) to listen for traffic, is:
nc -w 300 -l 5600 | zfs recv -Fduv backup
(first doubt: -w with -l probably ineffective...)
sending side (IP 192.168.1.116) CLI command (snapshot is @001):
zfs send -R tank/music@001 | nc -w 30 -v 192.168.1.117 5600
When the job is done, next command on the backup machine is:
zfs set readonly=on backup/music
1st question: I'd like to monitor zfs send/receive process by piping the send command to pv, like:
zfs send -R tank/music@001 | pv -i 10 | nc -w 30 -v 192.168.1.117 5600
but seems that pv is not available in FreeNAS.
2nd question: how do I quickly check that the zfs send/receive operation has completed without errors? Because, If I hit Ctrl+C on the receiving side (killing nc listening) I don't see any errors.
3rd question: how do I automatically kill the netcat listening process on the receiving machine? The -w switch seems sorting no effect.
