bullerwins
- Mar 15, 2022
Hi!
I have a 4x14TB RAIDz2 pool and want to add an additional 14TB drive. I know you can't add a drive to an existing pool, that why I'm backing up up all my data to a remote server (at 70MB/s so it's going to take around 4 days).
The remote server doens't run ZFS, so I'm using rsync to copy the data.
The problem I'm facing is when I recreate the pool, what's the best way to recreate the datasets, permissions, shares etc? Do I have to do it manually?
The workflow is the following:
1) Rsync all the /mnt/pool/datasets to /remote/datasets
2) Delete the current pool
3) Create a new pool with the new disk, 5x14TB RAIDz2
4) Create all the datasets in the pool again
5) Copy back the data into the datasets
6) Configure the permissions
7) Configure the shares
My question is if there is a way to backup/import steps 4, 6 and 7 to be sure I don't miss anything.
Would clients like mac and windows machines detect the new shares plug and play if the name/credentials/IP etc is the same?
PD: The pool also has a SSD as a L2arc if that matters, I would guess it doens't, just add the disk as "cache" type.
