Tony Self
 - Jan 30, 2017
Hi Guys,
I need some help.
I am currently running 9.10.2-U6 to host my Plex Media Server. I have a number of plugins installed (Plex, Sabnzbd, Sickrage, Transmission, Couchpotato) and additional jails for RClone and OpenVPN.
The Sickrage and Couchpotato plugins automatically update. Plex and Sabnzbd are manual updates. They are on the most up to date plugin at the moment, but not on the most up to date version of the apps.
First question - Are the plugins for 9.10.2 still being worked on or do i need to upgrade to 11.1 to be available to upgrade Plex and Sabnzbd?
Everything is running fine on 9.10.2-U6 as far as I am concerned (apart from app upgrades mentioned above), but from what I have read 11.1 will give me some performance improvements and the new Cloud Sync feature will potentially improve my syncing ability with my Google Drive over using RClone.
Second Question (and probably the most important one) - Is now the time for me to upgrade or do I follow the mantra "if it ain't broke, leave it alone". I know at sometime I will have to upgrade, but what I don't want to do is upgrade and then run into problems with my Plugins and Jails.
Third Question - From what I have read, my warden based jails will continue to function without issue under 11.1. Am I correct in this understanding.
Final Question - If I do upgrade am I right is saying all I have to do is change to the FreeNAS-11-STABLE stream and check for updates and proceed from there? And if I do run into problems is the upgrade irreversible, will I be able to revert back to the 9.10 stream?
I look forward to your feedback.
Thanks
Tony Self
			I need some help.
Thanks
Tony Self
