I'm currently running 8.0-RELEASE on a USB flash drive. To upgrade to 8.2, can I simply save my existing config, build a new flash drive w/ 8.2, boot from it, then upload my old config? Thanks in advance.
Keep in mind the image size has changed, so use a 4GB USB key.
Personally I would make an intermediate hop & go to 8.0.4 or something since you are more than a year old & there have been a *ton* of changes....it might be that your config won't update cleanly coming from something so old. Of course if you are starting with a fresh USB key there's no reason not to just go with 8.2 & see what happens.
Thanks survive, highly appreciated. I was concerned about trying to upload a config while jumping two point releases.
Updated:
Your suspicions were correct. Uploading the 8.0 config to 8.2 did not work (the system hung right after the bootloader). But doing the two-step upgrade from 8.0 -> 8.0.4 -> 8.2 worked just fine. Thanks again.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
