Updated jail template for 11.1?
ryanhunt
So I went to install the Unifi port today, and was greeted with this error:
root@unifi:/usr/ports/net-mgmt/unifi5 # make install clean
/!\ ERROR: /!\
Ports Collection support for your FreeBSD version has ended, and no ports are
guaranteed to build on this system. Please upgrade to a supported release.
No support will be provided if you silence this message by defining
ALLOW_UNSUPPORTED_SYSTEM.
*** Error code 1
Stop.
make: stopped in /usr/ports/net-mgmt/unifi5
Thanks to @FlamingPooh from this post, it's clear that support for FreeBSD 11.0 has ended on November 30, 2017 which is likely causing this error. There doesn't appear to be any obvious fixes for this - but I would have thought there'd be an updated jail template by now?
Are there any plans to release an updated jail template for FreeBSD 11.1-Stable to match the release of FreeNAS 11.1-Release?
