OK, here's a hack for you.
If you amend the device detection code as follows, you should be able to specify pool specific devices, eg --devices 'music:da5,da6 tank:ada1,ada2,ada3' (the format being pool name, a colon, comma separated devices then a single space for the next pool and devices etc.). Iif you don't specify devices for a particular pool they will be retrieved from the config database.
EDit: Here's the whole sasidle script, which should support multiple pools when called by the startup daemon, and also and device specific pools.
#!/bin/sh
#set -xv
#VERSION: 0.3.3
#MODIFIED: 22 Oct 2013
#AUTHOR: Milhouse
#DESCRIPTION: Created on FreeNAS 8.0.1-BETA4 with LSI 9211-8i HBA
# Tested on FreeNAS 8.0.2-RELEASE with LSI 9211-8i HBA
# Tested on FreeNAS 9.1.1-RELEASE with onboard SATA
# This script will attempt to stop disks in a ZFS pool connected
# by a SAS HBA controller, using the camcontrol command. In effect,
# this is a poor mans ATAIDLE.
# The script is designed to run as a "daemon" process, running
# constantly from bootup. The idea is that it will consume standard
# input, which will itself be the output of "zpool iostat n" where n
# is a time interval, usually 60 (seconds).
# A count (--timeout) is specified as an argument for the script, and this
# quantity is decremented each time there is no iostat activity, and reset
# whenever there is iostat activity. When the count reaches zero, the disks
# will be stopped using "camcontrol stop" (unless the --test option is
# specified).
# The amount of time elapsed before disks are stopped is calculated as
# the product of the timeout and the value n specified for zpool iostat.
# For example, a timeout of 15 and an interval of 60 gives 15 * 60, or
# 900 seconds (ie. 15 minutes). The default timeout is 30.
# By default, disks will be stopped asynchronously (ie. simultaneously)
# however if this is a problem, specify the --sync option to stop disks
# in sequence, one after the other.
# If a system has multiple pools, run individual commands for each pool.
# If the script is unable to automatically detect disks/devices, specific
# devices can be specified using the --devices argument.
#CHANGELOG:
# 0.1.0: 2011-08-01 - Initial version
# 0.2.0: 2011-09-05 - Tweak CAMCONTROL detection
# 0.2.1: 2011-10-08 - Rewrite device detection to read devices from SQLITE db
# 0.2.2: 2011-11-11 - Log when new disc activity detected after a stop (disable with --nologstart)
# Simplify logging.
# 0.2.3: 2011-11-12 - Minor fix for logging.
# 0.3.0: 2012-06-04 - Add support for multiple pools and pool specific devices
# 0.3.1: 2012-06-05 - Minor coding style corrections, remove trailing comma from default pools
# 0.3.2: 2012-06-17 - Fix regression decoding devices and expansion of args
# 0.3.3: 2013-10-22 - Fix unterminated string which FreeNAS 9.1.1 detects (but wasn't a problem in FreeNAS 8.x!)
#USAGE:
# Execute the script with the -h or --help arguments.
#EXAMPLES:
# zpool iostat tank 60 | sh sasidle --timeout 15
# zpool iostat tank 60 | sh sasidle --timeout 15 --devices "/dev/da[2-3]"
# zpool iostat tank 60 | sh sasidle --timeout 15 --devices "tank:/dev/da[1-2] music:/dev/da[3-4]" --pool tank,music
# zpool iostat tank 60 | sh sasidle --timeout 15 --sync
# zpool iostat tank 60 | sh sasidle --timeout 15 --test --verbose
POOL=`zpool list -H -o name | tr -s '\n' ',' | sed 's/,$//g'`
INTERVAL=60
TIMEOUT=30
DEVICES=
ASYNC=Y
LOGSTART=Y
DOSTOP=Y
DEBUG=
INFO=Y
_log() {
[ ! -z $RC_PID ] && echo "$1" || echo "`date +'%Y/%m/%d %H:%M:%S'` $1"
_help() {
echo "usage: ${0} [-p --pool <pool1,pool2>] [-i --interval #] [-t --timeout #] [-s -sync]
[-d --devices "pool1:/dev/da[0-2] pool2:/dev/da[3-6]"] [--nologstart] [-x --test]
[-q --quiet|-v --verbose] [-h --help]
-p --pool name of pool(s) to monitor, comma separated list
-i --inteval time interval between checks, in seconds
-t --timeout number of intervals to elaps before stopping disks (default 30)
-s --sync stop disks synchronously (default, async)
-d --devices override device detection by specifying devices eg. "/dev/da[0-4]",
or pool specific (pool1:dev1,dev2 pool2:dev3,dev4)
--nologstart log message when disk activity detected after a prior stop
-x --test do not stop disks (simulation)
-q --quiet suppress all informational and debug messages
-v --verbose output debug messages
-h --help display this help"
# Total hack to avoid consuming arguments (needed for later expansion)
# getopts doesn't support long options in BSD, so this hack will have
# to do.
# In order to kick off the background task, we only need to know --pool
# and --interval so make sure they're first in any arguments, and we'll
# pass them in again to the background job where they can be consumed...
P=1
while [ $P -le $# ]; do
[ $P -gt 9 ] && break;
ARG1=`eval echo \$"$P"`
let P=P+1 >/dev/null
ARG2=`eval echo \$"$P"`
let PN=P+1 >/dev/null
case ${ARG1} in
"-p" | "--pool") POOL=${ARG2}; P=$PN;;
"-i" | "--interval") INTERVAL=${ARG2}; P=$PN;;
esac
done
# Being called by rc - fork off a backgroun task
if [ ! -z $RC_PID ]; then
if [ -z ${PROCMAIN} ]; then
export PROCMAIN=YES;
for p in `echo ${POOL} | sed "s/,/ /g"`; do
zpool list $p >/dev/null
# Pool must exist - if not, ignore it (error message will appear in logs)
if [ $? -eq 0 ]; then
zpool iostat ${p} ${INTERVAL} | \
/bin/sh $0 "$@" --pool ${p} --interval ${INTERVAL} | \
logger -i -t sasidle &
fi
done
exit 0
fi
echo $$ >>/var/run/sasidled.pid
fi
# To have got here, we're either being run manually from the command line, or
# called from rc, so lets validate all arguments - they're safe to consume now.
while [ $# -gt 0 ]; do
case ${1} in
"-p" | "--pool") shift 1; POOL=${1};;
"-i" | "--interval") shift 1; INTERVAL=${1};;
"-t" | "--timeout") shift 1; TIMEOUT=${1};;
"-s" | "--sync") ASYNC=;;
"-d" | "--devices") shift 1; DEVICES=${1};;
"--nologstart") LOGSTART=;;
"-x" | "--test") DOSTOP=;;
"-q" | "--quiet") DEBUG=; INFO=;;
"-v" | "--verbose") DEBUG=Y; INFO=Y;;
"-h" | "--help") _help; exit;;
*) echo "Unrecognised argument: $1"; _help; exit;;
esac
shift 1
done
[ "${INFO}" ] && _log "$0 starting"
if [ "${DEVICES}" ]; then
TEMP_DEV=${DEVICES}
DEVICES=
for x in ${TEMP_DEV}; do
if [ -n "$(echo $x | grep "^${POOL}:")" ]; then
[ "${INFO}" ] && _log "Parsing devices for pool \"${POOL}\"..."
DEVICES="`echo "$x" | cut -d: -f2- | sed 's/,/ /g'`"
break
fi
# Use these unamed devices if no pool is matched
[ `echo $x | grep -v ":"` ] && DEVICES="${DEVICES} $x"
done
# Clean up devices if necessary...
[ "$DEVICES" ] && DEVICES=`eval echo '$DEVICES' | sed 's/,/ /g' | sed 's/"//g'`
fi
# Determine managed devices if not already known...
if [ ! "${DEVICES}" ]; then
[ "${INFO}" ] && _log "Identifying devices for pool \"${POOL}\"..."
OLD_RC_PID=$RC_PID
. /etc/rc.freenas
RC_PID=$OLD_RC_PID
DEVICES=`${FREENAS_SQLITE_CMD} ${FREENAS_CONFIG} \
"SELECT disk_name FROM storage_disk \
WHERE LOWER(disk_description) LIKE LOWER('% ${POOL} %') \
ORDER BY disk_name ASC" | \
while read disk_name; do
echo $disk_name|sed "s/p.$//"
done|tr -s "\n" " "`
fi
# Strip /dev/ prefix, eliminate any duplicates and stop disks in ascending sequence...
DEVICES=`echo ${DEVICES} | sed "s#/dev/##g" | tr -s " " "\n" | sort -u | tr -s "\n" " "`
# Show config info...
if [ "${INFO}" ]; then
_log "---------------------------------------------------------"
_log "Monitored Pool: ${POOL}"
_log "Monitored Devices: ${DEVICES}"
_log "Polling Interval: ${INTERVAL} seconds"
_log "Idle Timeout: ${TIMEOUT} * ${INTERVAL} seconds"
_log "ASync Enabled: $([ ${ASYNC} ] && echo "Yes" || echo "No")"
_log "Simulated Stop: $([ ${DOSTOP} ] && echo "No" || echo "Yes")"
_log "Log Disk Start: $([ ${LOGSTART} ] && echo "Yes" || echo "No")"
_log ""
fi
# Skip 3 lines of "zpool iostat" headers...
for H in 1 2 3; do
read HEADER
[ "$DEBUG" ] && _log "$(printf "%.3d: %s\n" ${TIMEOUT} "${HEADER}")"
done
COUNT=${TIMEOUT}
STOPPED=
# Main infinite loop...
while [ true ]; do
read POOL_NAME POOL_USED POOL_AVAIL POOL_OP_READ POOL_OP_WRITE POOL_BW_READ POOL_BW_WRITE
# If no activity, decrement count, else reset it
if [ ${POOL_OP_READ-1} = 0 -a ${POOL_OP_WRITE-1} = 0 -a \
${POOL_BW_READ-1} = 0 -a ${POOL_BW_WRITE-1} = 0 ]; then
[ ! ${STOPPED} ] && let COUNT=COUNT-1 >/dev/null
else
if [ "${STOPPED}" -a "${LOGSTART}" ]; then
[ "${INFO}" ] && _log "** Restarting devices in pool \"${POOL_NAME}\" due to activity **"
fi
COUNT=${TIMEOUT}
STOPPED=
fi
# Optional diagnostic output...
[ "${DEBUG}" ] && _log "$(printf "%.3d: %-10s %5s %5s %5s %5s %5s %5s\n" \
${COUNT} ${POOL_NAME} ${POOL_USED} ${POOL_AVAIL} \
${POOL_OP_READ} ${POOL_OP_WRITE} ${POOL_BW_READ} ${POOL_BW_WRITE})"
# If count reaches zero, stop devices
if [ ${COUNT} -le 0 -a ! "${STOPPED}" ]; then
[ "${INFO}" ] && _log "** Stopping devices in pool \"${POOL_NAME}\" **"
for DISK in ${DEVICES}; do
if [ "${DOSTOP}" ]; then
[ "${INFO}" ] && _log "camcontrol stop ${DISK}"
[ "${ASYNC}" ] && camcontrol stop ${DISK} &
[ ! "${ASYNC}" ] && camcontrol stop ${DISK}
else
[ "${INFO}" ] && _log "#camcontrol stop ${DISK}"
fi
done
STOPPED=Y
fi
done
exit 0
