Milhouse
- Jun 1, 2011
I may be missing the obvious, but that output looks OK to me - there is no activity in the "music" pool so the script has stopped (or attempted to stop) the disks associated with the music pool. The "tank" pool continues to report activity, so no attempt is made to stop those disks.
I can't explain your power consumption observations, but certainly the script *seems* to be working as expected and as such I would expect you to see a reduction in power consumption once the two disks have been spun down. Can you confirm if you are able to hear the da5/da6 disks spinning down (and then spinning back up when you access them again)? If the disks aren't actually spinning down, then that would suggest a problem with camcontrol.
At the command line, try running the following commands - assuming there are no errors you should hear the disks spin down:
If you then access the pool associated with those disks, you should be able to hear them spinning up again.
camcontrol stop da5 camcontrol stop da6
