travalon
- Jan 6, 2013
Ok, strike 2. I rushed ahead and picked up a pci raid card to expand capacity. Didn't check the compatibility list and guess what. NOT supported. MY build is as follows:
Old Dell mid tower
GIGABYTE GA-G41MT-S2PT LGA 775 Intel G41 Micro ATX Intel Motherboard
C2D E6400
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory
Rosewill RC-209-EX PCI 2.3, 32bit, 33/66Mhz SATA Controller Card (4 sata 3gb ports)
CORSAIR Builder Series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
2x Western Digital Red WD20EFRX 2TB IntelliPower SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
2x Seagate Momentus XT ST95005620AS 500GB 7200 RPM 2.5" SATA 3.0Gb/s with NCQ Solid State Hybrid Drive -Bare Drive = 1Tb
2x 250gb ide notebook drive with sata adapters = 500gb
I went into the bios of the card to make sure it was set up as JBOD and as near as I can tell it is since there are no raids setup. The card does see the 2 250 GB HDDs but of course Freenas can't. I do have a Linux driver for the card.
The Card is as above a Rosewill RC-209-EX PCI 32 bit. Is there a way I can install the driver into freenas and get the card working?
I know poor planning on my part doesn't constitute an emergency on your part.
I really appreciate everyone's help.
Old Dell mid tower
C2D E6400
