Nogtail
- Dec 29, 2022
I recently built myself a system which uses 6 x 8TB IronWolf drives in a RAID-Z2 configuration. I have created the pool and vdev, however I have not shared it or put any files on it. The system dataset is located on the boot pool so it should not be accessing the drives either. All other settings are installation defaults.
The hard drives are making constant noise as though they are accessing/writing data. Disk I/O graphs and gstat show no activity on anything but the boot drive. The SMART data shows 25 power on hours, slightly over 1 hour of head flying time and a load cycle count of over 240. I ran the command a few minutes later and the load cycle count had increased by another 4. The SMART values for all disks are almost identical.
What is causing all the disk activity? Is there any way I can keep the load cycle count down? At this rate they'll be reaching the rated 600,000 in only a few years.
