testfire10
- Aug 1, 2021
Hi everyone. I have a pool with 6 disks in RAID Z2. In the last few days one of the disks has failed the long and short SMART tests. Below, I've given the results from some of the smartctl commands I've run. My question is should I replace this disk now? Has it actually failed? Is there some other commands I should run to ascertain its condition?
12/29/2021 truenas# smartctl -i -H -A /dev/da0 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p11 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: HGST Product: H7280B520SUN8.0T Revision: A3Y1 Compliance: SPC-4 User Capacity: 7,865,536,647,168 bytes [7.86 TB] Logical block size: 512 bytes Physical block size: 4096 bytes Formatted with type 1 protection 8 bytes of protection information per logical block LU is fully provisioned Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000cca25257042c Serial number: 001809SJVJJN 7SHJVJJN Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Wed Dec 29 11:38:04 2021 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Grown defects during certification <not available> Total blocks reassigned during format <not available> Total new blocks reassigned <not available> Power on minutes since format <not available> Current Drive Temperature: 21 C Drive Trip Temperature: 85 C Accumulated power on time, hours:minutes 28470:47 Manufactured in week 09 of year 2018 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 37 Specified load-unload count over device lifetime: 600000 Accumulated load-unload cycles: 1200 Elements in grown defect list: 0 Vendor (Seagate Cache) information Blocks sent to initiator = 14309183256002560 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 6697 0 6697 7597776 4499917.559 0 write: 0 0 0 0 2092002 191683.219 0 verify: 0 0 0 0 203765 0.007 0 Non-medium error count: 0 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Failed in segment --> 3 28387 - [0x1 0xb 0x96] # 2 Background long Failed in segment --> 3 28298 - [0x1 0xb 0x96] # 3 Background short Failed in segment --> 3 28298 - [0x1 0xb 0x96] # 4 Background short Failed in segment --> 3 28219 - [0x1 0xb 0x96] # 5 Background short Completed - 28051 - [- - -] # 6 Background short Completed - 27883 - [- - -] # 7 Background short Completed - 27715 - [- - -] # 8 Background short Completed - 27547 - [- - -] # 9 Background short Completed - 27379 - [- - -] #10 Background short Completed - 27210 - [- - -] #11 Background short Completed - 27042 - [- - -] #12 Background short Completed - 26874 - [- - -] #13 Background short Completed - 26706 - [- - -] #14 Background short Completed - 26538 - [- - -] #15 Background short Completed - 26370 - [- - -] #16 Background short Completed - 26202 - [- - -] #17 Background short Completed - 26034 - [- - -] #18 Background short Completed - 25866 - [- - -] #19 Background short Completed - 25699 - [- - -] #20 Background short Completed - 25531 - [- - -] Long (extended) Self-test duration: 59291 seconds [988.2 minutes]
