FreeNasJoe
- Nov 21, 2016
I'm seeing the following error messages continuously in the console messages area in the footer of the freeNAS web GUI:
ada6 is a 256GB SSD used for storing jails.
I saw from another similar post the suggestion to run the command:
Here is the output of this command:
I think this says the SSD (ada6) is physically okay meaning this is a data corruption problem and not a hardware problem. Is this correct?
I'd appreciate any suggestions on how to go about clearing / correcting the error.
Dec -- --:31:59 freenas (ada6:ahcich6:0:0:0): Retrying command
Dec -- --:31:59 freenas (ada6:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 68 90 ab c1 40 0e 00 00 00 00 00
Dec -- --:31:59 freenas (ada6:ahcich6:0:0:0): CAM status: Uncorrectable parity/CRC error
Dec -- --:32:03 freenas (ada6:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 e0 20 13 45 40 08 00 00 00 00 00
Dec -- --:32:03 freenas (ada6:ahcich6:0:0:0): CAM status: Uncorrectable parity/CRC error
Dec -- --:32:03 freenas (ada6:ahcich6:0:0:0): Retrying command
Dec -- --:32:03 freenas (ada6:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 30 30 9a 09 40 02 00 00 00 00 00
smartctl -a -q noserial /dev/ada6
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Samsung based SSDs
Device Model: Samsung SSD 850 PRO 256GB
Firmware Version: EXM02B6Q
User Capacity: 256,060,514,304 bytes [256 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Dec -- --:26:33 2017 MST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 133) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 717
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 13
177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 4
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 074 064 000 Old_age Always - 26
195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 083 083 000 Old_age Always - 16835
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 10
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 1663635028
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 287 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
255 0 65535 Read_scanning was never started
