andreaconfa
- Jun 30, 2019
Hi all, i'm new here.
I have a FreeNas server running since 2 month and in this days i'm having a tons of this error in the email report:
smartctl -a /dev/ada0 shows:
I'm at risk to loose my data?
What i can do to solve the problem, if is possibile?
Thanks all :)
> (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 72 5a 40 18 00 00 01 00 00 > (ada0:ahcich0:0:0:0): CAM status: Uncorrectable parity/CRC error > (ada0:ahcich0:0:0:0): Retrying command
root@FreeNAS[~]# smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1ER166
Serial Number: W7P00D5J
LU WWN Device Id: 5 000c50 077f17b06
Firmware Version: CC43
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Jul 1 08:15:55 2019 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 89) seconds.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 329) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 112 099 006 Pre-fail Always - 44172072
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 641
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 073 060 030 Pre-fail Always - 21956119
9 Power_On_Hours 0x0032 081 081 000 Old_age Always - 17302
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 395
183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 096 000 Old_age Always - 0 0 142
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 064 053 045 Old_age Always - 36 (Min/Max 25/38)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 39
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 813071
194 Temperature_Celsius 0x0022 036 047 000 Old_age Always - 36 (0 12 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 194 000 Old_age Always - 1252
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 9242h+56m+55.343s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 11608309136
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 21363996753
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
- Asus B85 Pro GAMER
- Intel i5 4570
- Ram 8GB DDR3
- 2xWD RED 4TB MIRRORED, 2xWD RED 3TB MIRRORED, 1x Seagate Barracuda 3 TB (the one with the error), and boot drive 250gb WD BLUE
- Hard disk controllers: Motherboard integrated
- Network cards: TPLINK TG-3468
Thanks all :)
