Unable to set disk offline
I have a disk showing:
Device: /dev/da1 [SAT], 8 Currently unreadable (pending) sectors.
It passes a long smart test, but it has high power-on hours so I thought I'd go ahead and replace it.
When I go to Pool -> Status -> da1 -> offline nothing happens. There are no errors that I see, nothing in /var/log/messages.
I also tried it from the CLI, same experience. No errors, just nothing happens.
System:
TrueNAS Core 13.0-U4
Supermicro X10SLL-F
i3-4130
16 GB RAM (4x4GB Kingston KVR13E9/4I ECC)
(3) 8TB Western Digital Ultrastar He10/12 (Model: WDC WD80EMAZ-00WJTA0)
[@freenas ~]$ zpool status
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0B in 00:00:28 with 0 errors on Wed Mar 15 03:45:28 2023
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          mirror-0    ONLINE       0     0     0
            ada0p2    ONLINE       0     0     0
            ada1p2    ONLINE       0     0     0
errors: No known data errors
  pool: storage0
 state: ONLINE
  scan: scrub repaired 0B in 04:38:02 with 0 errors on Sun Feb 26 04:38:02 2023
        storage0                                        ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            da0p2                                       ONLINE       0     0     0
            gptid/0e7adb81-10cc-11e6-afcb-002590d4cb9b  ONLINE       0     0     0
            gptid/1c3a42d0-0faa-11e6-aaf8-002590d4cb9b  ONLINE       0     0     0
  pool: storage1
 state: ONLINE
  scan: resilvered 300K in 00:00:00 with 0 errors on Wed Mar 15 13:25:21 2023
        storage1    ONLINE       0     0     0
            da2p2   ONLINE       0     0     0
            da3p2   ONLINE       0     0     0
            da1p2   ONLINE       0     0     0
[@freenas ~]$ sudo smartctl -x /dev/da1
Password:
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family:     Western Digital Ultrastar He10/12
Device Model:     WDC WD80EMAZ-00WJTA0
Serial Number:    1SHJV9LZ
LU WWN Device Id: 5 000cca 26bd5c034
Firmware Version: 83.H0A83
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Mar 15 13:28:40 2023 EDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 976) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  --S---   128   128   054    -    116
  3 Spin_Up_Time            POS---   156   156   024    -    397 (Average 446)
  4 Start_Stop_Count        -O--C-   100   100   000    -    35
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         -O-R--   100   100   067    -    0
  8 Seek_Time_Performance   --S---   128   128   020    -    18
  9 Power_On_Hours          -O--C-   095   095   000    -    40564
 10 Spin_Retry_Count        -O--C-   100   100   060    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    35
 22 Helium_Level            PO---K   100   100   025    -    100
192 Power-Off_Retract_Count -O--CK   098   098   000    -    3122
193 Load_Cycle_Count        -O--C-   098   098   000    -    3122
194 Temperature_Celsius     -O----   135   135   000    -    48 (Min/Max 25/62)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    8
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   5501  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%     40551         -
# 2  Short offline       Completed without error       00%     40527         -
# 3  Short offline       Completed without error       00%     40503         -
# 4  Short offline       Completed without error       00%     40480         -
# 5  Short offline       Completed without error       00%     40456         -
# 6  Short offline       Completed without error       00%     40432         -
# 7  Short offline       Completed without error       00%     40407         -
# 8  Short offline       Completed without error       00%     40383         -
# 9  Extended offline    Completed without error       00%     40361         -
#10  Short offline       Completed without error       00%     38652         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        Active (0)
Current Temperature:                    48 Celsius
Power Cycle Min/Max Temperature:     45/56 Celsius
Lifetime    Min/Max Temperature:     25/62 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (104)
Index    Estimated Time   Temperature Celsius
 105    2023-03-15 11:21    48  *****************************
 ...    ..( 58 skipped).    ..  *****************************
  36    2023-03-15 12:20    48  *****************************
  37    2023-03-15 12:21    49  ******************************
  38    2023-03-15 12:22    48  *****************************
 ...    ..( 65 skipped).    ..  *****************************
 104    2023-03-15 13:28    48  *****************************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              35  ---  Lifetime Power-On Resets
0x01  0x010  4           40564  ---  Power-on Hours
0x01  0x018  6     57385267769  ---  Logical Sectors Written
0x01  0x020  6       539377177  ---  Number of Write Commands
0x01  0x028  6    489347405747  ---  Logical Sectors Read
0x01  0x030  6      2278363361  ---  Number of Read Commands
0x01  0x038  6    146031775800  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           40068  ---  Spindle Motor Power-on Hours
0x03  0x010  4           40068  ---  Head Flying Hours
0x03  0x018  4            3122  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4            5199  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              48  ---  Current Temperature
0x05  0x010  1              48  N--  Average Short Term Temperature
0x05  0x018  1              50  N--  Average Long Term Temperature
0x05  0x020  1              62  ---  Highest Temperature
0x05  0x028  1              25  ---  Lowest Temperature
0x05  0x030  1              60  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              54  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               8  ---  Number of Hardware Resets
0x06  0x010  4             124  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
Index                LBA    Hours
    0        11466502344        -
    1        11466502345        -
    2        11466502346        -
    3        11466502347        -
    4        11466502348        -
    5        11466502349        -
    6        11466502350        -
    7        11466502351        -
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            7  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            8  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
