SMART Test Results Help
kriknav
I have noticed that one of my drives has started increasing the error count consistently the last two times it's done a extended offline test. The short offline tests, pass, but the extended ones fail. Looking at the SMART data, it seems like the drive is ok, but I'm wondering if someone can help me understand what is causing the issue so I can try to resolve it, or at least know if I need to start shopping for a replacement disk.
Thank you in advanced.
Hardware:
I have a Freenas-Mini-3.0-E+ running TrueNAS 13.0-U5.1 with 4 WD Red 4TB WD40EFRX. Everything has been running without issue for over 3 years now.
SMART output:
root@freenas[~]# smartctl -x /dev/ada1
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68N32N0
Serial Number:    WD-WCC7K6KS388C
LU WWN Device Id: 5 0014ee 26864af28
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Jan 23 11:32:49 2024 PST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 116) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (44520) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 472) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   169   169   021    -    6550
  4 Start_Stop_Count        -O--CK   100   100   000    -    8
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   065   065   000    -    26118
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    7
192 Power-Off_Retract_Count -O--CK   200   200   000    -    0
193 Load_Cycle_Count        -O--CK   200   200   000    -    63
194 Temperature_Celsius     -O---K   111   103   000    -    39
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      56  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
        CR     = Command Register
        FEATR  = Features Register
        COUNT  = Count (was: Sector Count) Register
        LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
        LH     = LBA High (was: Cylinder High) Register    ]   LBA
        LM     = LBA Mid (was: Cylinder Low) Register      ] Register
        LL     = LBA Low (was: Sector Number) Register     ]
        DV     = Device (was: Device/Head) Register
        DC     = Device Control Register
        ER     = Error register
        ST     = Status register
Error 1 [0] occurred at disk power-on lifetime: 25346 hours (1056 days + 2 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  04 -- 51 00 00 00 01 01 fb a2 b8 40 00
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  ea 00 00 00 00 00 00 00 00 00 00 40 08  6d+19:52:51.019  FLUSH CACHE EXT
  61 00 18 00 e0 00 01 88 6e fe b8 40 08  6d+19:52:51.018  WRITE FPDMA QUEUED
  61 00 08 00 d8 00 01 6e 88 15 f0 40 08  6d+19:52:51.018  WRITE FPDMA QUEUED
  61 00 08 00 d0 00 01 6e 44 18 d8 40 08  6d+19:52:51.018  WRITE FPDMA QUEUED
  61 00 10 00 c8 00 01 52 93 f7 f8 40 08  6d+19:52:51.018  WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed: read failure       40%     26094         4328235704
# 2  Short offline       Completed without error       00%     26020         -
# 3  Short offline       Completed without error       00%     25876         -
# 4  Short offline       Completed without error       00%     25685         -
# 5  Short offline       Completed without error       00%     25446         -
# 6  Extended offline    Completed: read failure       40%     25352         4328235704
# 7  Short offline       Completed without error       00%     25278         -
# 8  Short offline       Completed without error       00%     25134         -
# 9  Short offline       Completed without error       00%     24943         -
#10  Short offline       Completed without error       00%     24727         -
#11  Extended offline    Completed without error       00%     24637         -
#12  Short offline       Completed without error       00%     24559         -
#13  Short offline       Completed without error       00%     24415         -
#14  Short offline       Completed without error       00%     24223         -
#15  Short offline       Completed without error       00%     23869         -
#16  Short offline       Completed without error       00%     23677         -
#17  Short offline       Completed without error       00%     23461         -
#18  Extended offline    Completed without error       00%     23372         -
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
Device State:                        Active (0)
Current Temperature:                    39 Celsius
Power Cycle Min/Max Temperature:     30/45 Celsius
Lifetime    Min/Max Temperature:     21/47 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (26)
Index    Estimated Time   Temperature Celsius
  27    2024-01-23 03:35    39  ********************
 ...    ..(192 skipped).    ..  ********************
 220    2024-01-23 06:48    39  ********************
 221    2024-01-23 06:49    44  *************************
 ...    ..( 12 skipped).    ..  *************************
 234    2024-01-23 07:02    44  *************************
 235    2024-01-23 07:03    43  ************************
 248    2024-01-23 07:16    43  ************************
 249    2024-01-23 07:17    42  ***********************
 ...    ..( 24 skipped).    ..  ***********************
 274    2024-01-23 07:42    42  ***********************
 275    2024-01-23 07:43    41  **********************
 ...    ..( 40 skipped).    ..  **********************
 316    2024-01-23 08:24    41  **********************
 317    2024-01-23 08:25    40  *********************
 ...    ..( 94 skipped).    ..  *********************
 412    2024-01-23 10:00    40  *********************
 413    2024-01-23 10:01    39  ********************
 ...    ..( 90 skipped).    ..  ********************
  26    2024-01-23 11:32    39  ********************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4               7  ---  Lifetime Power-On Resets
0x01  0x010  4           26118  ---  Power-on Hours
0x01  0x018  6     59546345399  ---  Logical Sectors Written
0x01  0x020  6      2017429800  ---  Number of Write Commands
0x01  0x028  6    135470111579  ---  Logical Sectors Read
0x01  0x030  6       623633468  ---  Number of Read Commands
0x01  0x038  6      3830486784  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           25979  ---  Spindle Motor Power-on Hours
0x03  0x010  4           25967  ---  Head Flying Hours
0x03  0x018  4              63  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4              73  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4               0  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              39  ---  Current Temperature
0x05  0x010  1              40  ---  Average Short Term Temperature
0x05  0x018  1              37  ---  Average Long Term Temperature
0x05  0x020  1              47  ---  Highest Temperature
0x05  0x028  1              25  ---  Lowest Temperature
0x05  0x030  1              43  ---  Highest Average Short Term Temperature
0x05  0x038  1              29  ---  Lowest Average Short Term Temperature
0x05  0x040  1              41  ---  Highest Average Long Term Temperature
0x05  0x048  1              31  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4              74  ---  Number of Hardware Resets
0x06  0x010  4              43  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            2  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4      2262533  Vendor specific
It's failing SMART tests, definitely replace it.
kriknav
Ok, fair point. Is there anything in the SMART data that indicates what exactly is failing? All the SMART attributes seem in good condition.
Indeed, most of the data looks fine, which is more than a little unusual, but not unheard of. My take on this is that SMART tests are typically used as a criterion for in-warranty exchanges, so vendors are naturally encouraged to be loosey-goosey with their pass criteria. If even so the disk fails the test, something must be very wrong.
That's the error...
Then this line indicates that there's a bad sector found on each extended test in the numbered sector:
Seems to be in warranty (assuming 4 years).
What's curious is that it wasn't just remapped and logged... Rather the test just failed outright, multiple times. It must be more than just a bad sector.
oxyde
I have encountered the same "path", while testing a refurbished WD10EFRX before use: no errors logged, only error count increase and smart test fail everytime (the short one too). Maybe is not so unusual :D
What was courious for me, was the fact the same disk, tested with third party program (Crystal disk info) show an healthy drive... obviously i send it back and get total refund
kriknav
Yea, I have not warranty path, it seems. 3-year warranty expired Jan. 17, 2024...figures. So I guess I'll look at replacing it when I get a chance. Any idea when TrueNAS will decide it's bad and kick it out? So far the array has been fine, but I'm guessing if this disk gets kicked out the pressure is on to replace it, just trying to gauge how long I have.
ChrisRJ
No, the array is not fine. It is just that the last of defense has not been breached yet. If you want to wait until then, that is of course your prerogative. But it is risky, because "defense lines" (to continue with the figure of speech) do not break in a linear way. So any second the drive can be gone. What that means for your data is not clear, because you did not specify your pool setup.
If you run TrueNAS this is an indicator that you care about your data. In that case, I would run for a new disk.
kriknav
Well it seems that the drive was still under warranty for another 20 days, so WD is replacing it under warranty, so they agreed with your assessment, though, surely no justification was needed.
Thank you all for your thoughtful insight in helping resolve this issue. I appreciate it all.
