I've got a new (started with the 9.10 nightlies, swithed to stable when 9.10 was released) freenas build and am running in to a problem with either my disks (no smart errors) or something else, and i'd like to know how to make sure.
The thing is, i bought 12 new drives in groups of 4.
One of the shipments contained drives with the same manufacturing date
1 of these drives had to be rma'd already.
Because of this i am not really confident in the other 3 drives of this group due to the possibility of a bad batch, but they didn't show any problems in my initial testing, and still show nothing strange in smart data.
I've been trying various nas os'es for the past 2 months, circling back to what i started with and sort of worked, freenas, only now there was 9.10 and everything seemed to work.
For the last week i've been installing and setting up a number of plugins, located on a 4-disk (zfs mirror, HGST 5K4000) volume which also holds the system dataset, and been copying data to another volume (10-disk raidz2, brand-new WD red's).
Yesterday i woke up to my pc having halted its file transfer.
Logging in to freenas i see that there are 2 alerts (don't remember the exact drive in the first error message):
1 drive unable to open + 2 drives gone on a raidz2 = volume offline
rebooting freenas leaves me with just the second alert message, all 10 disks are there again as they should, volume is online again.
I checked smart status on all drives and found raw values were all 0 where the should be 0, so my disks are ok?
I had been mucking about trying to get my second nic to work in one of the plugins, failed and couldn't get it to work again on the first nic, + some other plugins i could no longer connect to their webgui, while others requiring the same permissions still worked so i couldn't figure out what was wrong.
i thought it best to do a fresh install.
I detached the 10 drive volume and detached and wiped the 4-disk volume.
After setting up the new install (9.10 release, updated) initialising the 4-disk volume and importing the existing 10 drive volume i did a zpool clear to remove the previous errors.
Yesterday evening i resumed copying files over to the 10-disk volume.
Today i again wake up to my pc having halted its file transfer.
This time in freenas:
Pool is 'healthy' again after reboot.
Still nothing to see in smart data. (Manually started a long smart test on all drives in the 10-disk pool, will be done tomorow morning.)
Since there is nothing to see in the smart data (yet), how do i tell for sure if this issue is related to a disk failing, or what might be another reason for it?
Thank you.
smart output for aforementioned dev/da0:
running FreeNAS-9.10-STABLE-201603252134
mobo: asus p10s-i
cpu: i3-6100t
ram: 2*16GB ECC
hba: highpoint dc7280
os: sandisk ultra 32GB
vol1: 4*HGST 5k4000 4TB in mirror
vol2: 10*WD red 6TB in raidz2
btw: both times, when a volume either went offline or degraded, i did not receive any email from freenas to notify me of this.
Meanwhile i did get a daily run output today that reflected the degraded state of the second pool, when i was already well aware, so it's not that email isn't working, but why then weren't there notifications sent?
- freenas Device: /dev/da* [SAT], unable to open device
- The volume S.01 (ZFS) state is OFFLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
- freenas Device: /dev/da0 [SAT], unable to open device
- The volume S.01 (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
Thank you.
[root@freenas] ~# smartctl -q noserial -a /dev/da0 smartctl 6.4 2015-06-04 r4109 [FreeBSD 10.3-RELEASE amd64] (local build) Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68L0BN1 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue Mar 29 11:11:56 2016 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART Status not supported: Incomplete response, ATA output registers missing SMART overall-health self-assessment test result: PASSED Warning: This result is based on an Attribute check. General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 248) Self-test routine in progress... 80% of test remaining. Total time to complete Offline data collection: ( 5384) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 707) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 230 198 021 Pre-fail Always - 7466 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 27 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 364 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 27 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 23 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 76 194 Temperature_Celsius 0x0022 125 114 000 Old_age Always - 27 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Aborted by host 10% 361 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@freenas] ~#
mobo: asus p10s-i
cpu: i3-6100t
ram: 2*16GB ECC
