SOLVED Unable to login after upgrading Truenas (2FA is invalid)
sdealmeida
I recently upgraded my server from TrueNAS-12.0-U6.1 to TrueNAS-12.0-U7 and after that, my 2FA stopped working correctly. Everytime I try to login, it states that my username/password or 2FA is incorrect. If I keep re-trying, I'm eventualy able to login (which tells me my username/password is correct). I use a password manager to store my username/password and 2FA code (I use 1Password).
The clock on my server is up to date and I've even tried waiting the 30 seconds for a new 2FA code to be generated, but I'm still unable to login at times. I've even reset my root password and generated a new 2FA code, but this issue still persists.
I haven't seen any other user report about this issue, so I don't know if its just me. I have a feeling this is a bug in the software since I've been using Truenas for many years now and this is the first time I'm running into this problem.
What should I do? Thanks!
Heracles
There have been many posts about 2FA...
And how did you identified that ? To eyeball the clock is not enough. Are you sure that your NTP config is working and that your server is in sync ?
Also, it is just as important for the client to be perfectly sync. The use of a smartphone often with that because they are naturally sync by the cellular network itself. If you are using a desktop as a client, be sure to get NTP working on that one too.
Samuel Tai
Are you sure your clock is up to date? What does ntpq -p show? Also, does the clock drift? What does sysctl kern.timecounter.choice show?
sdealmeida
This is what I see.
ntpq -p.
root@freenas[~]# ntpq -p
     remote           refid      st t when poll reach   delay   offset  jitter
 ntp.zaf.ca      .INIT.          16 u    - 1024    0    0.000   +0.000   0.000
 speedtest.switc .INIT.          16 u    - 1024    0    0.000   +0.000   0.000
 ntp-cov-1.lewis .INIT.          16 u    - 1024    0    0.000   +0.000   0.000
root@freenas[~]# sysctl kern.timecounter.choice
kern.timecounter.choice: ACPI-fast(900) i8254(0) HPET(950) TSC-low(1000) dummy(-1000000)
PS: I'm using Freebsd's default NTP servers (x.freebsd.pool.ntp.org, where x is 0 to 2).
Heracles
Stratum 16 and all zeroes mean that it does not sync.
Also, how about the sync client side ?
Samuel Tai
You're NOT sync'ed to NTP. Is your ISP blocking NTP? Try setting a sysctl tunable kern.timecounter.hardware="HPET" (in case your TSC drifts), and then running ntpdate 0.freebsd.pool.ntp.org.
A sync'ed system will have output like this:
root@raven:~ # ntpq -p
-a08.alphasrv.ne 124.216.164.14   2 u  291 1024  377  117.519   -2.190   0.612
*ntp2.your.org   .GPS.            1 u  189 1024  377   32.188   +1.334   0.456
+251.228.185.35. 169.254.169.254  3 u  258 1024  377   79.331   -2.848   0.606
+ntp2.as200552.n 202.70.69.81     2 u  302 1024  377   92.726   -0.678   0.490
sdealmeida
I'm getting the OTP code from my phone, so I think its synced
Odd, nothing about my setup changed recently (except updating to 12.0-U7).
I've added those tunnables to my config but I see the exact same results.
root@freenas[~]# ntpdate 0.freebsd.pool.ntp.org
13 Dec 23:13:48 ntpdate[84327]: the NTP socket is in use, exiting
Also, I saw a tunnable thats new to me (I haven't seen this before "hint.isp.0.role").
Samuel Tai
The hint.isp.x.role tunables are for the Enterprise edition's Fibre Channel support.
Try service ntpd stop, then ntpdate 0.freebsd.pool.ntp.org, and finally service ntpd start.
sdealmeida
Oh, I did the following and its giving me a different output now
root@freenas[~]# service ntpd stop
Stopping ntpd.
Waiting for PIDS: 1365.
13 Dec 23:29:56 ntpdate[94236]: step time server 192.241.146.233 offset +24.433896 sec
root@freenas[~]# service ntpd start
Starting ntpd.
root@freenas[~]# ntpq -pn
 5.9.124.124     .INIT.          16 u    -   64    0    0.000   +0.000   0.000
*194.0.5.123     209.51.161.238   2 u   11   64    1   14.234   -4.031   0.154
 54.39.23.64     .INIT.          16 u    -   64    0    0.000   +0.000   0.000
Odd, not really sure why this is happening though.
PS: This now shows in my web console
Dec 13 23:29:20 freenas 1 2021-12-13T23:29:20.119999-05:00 freenas.local ntpd 1365 - - ntpd exiting on signal 15 (Terminated)
Dec 13 23:29:56 freenas 1 2021-12-13T23:29:56.827256-05:00 freenas.local upsd 1387 - - Data for UPS [ups] is stale - check driver
Dec 13 23:29:56 freenas 1 2021-12-13T23:29:56.827908-05:00 freenas.local upsd 1387 - - UPS [ups] data is no longer stale
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004502-05:00 freenas.local ntpd 94259 - - ntpd 4.2.8p15-a (1): Starting
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004646-05:00 freenas.local ntpd 94259 - - Command line: /usr/sbin/ntpd -p /var/db/ntp/ntpd.pid -c /etc/ntp.conf -f /var/db/ntp/ntpd.drift -g
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004701-05:00 freenas.local ntpd 94259 - - ----------------------------------------------------
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004723-05:00 freenas.local ntpd 94259 - - ntp-4 is maintained by Network Time Foundation,
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004746-05:00 freenas.local ntpd 94259 - - Inc. (NTF), a non-profit 501(c)(3) public-benefit
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004780-05:00 freenas.local ntpd 94259 - - corporation.  Support and training for ntp-4 are
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004814-05:00 freenas.local ntpd 94259 - - available at https://www.nwtime.org/support
Dec 13 23:30:03 freenas 1 2021-12-13T23:30:03.004893-05:00 freenas.local ntpd 94259 - - ----------------------------------------------------
Samuel Tai
OK, you're starting to get sync'ed. One NTP server is locked in. You were 24 seconds behind NTP. Give it about 30 minutes, and 3-4 NTP servers will be locked in. Your 2FA should be more reliable now, but you should redo 2FA just to be safe.
sdealmeida
Looks like my issue has been resolved. I ended up changing the NTP servers to other NTP servers closer to me (using ntp.org servers).
Thanks!
