petemounce
 - Jul 17, 2016
I've just upgraded from 11.1-U6 to 11.1-U6.3 because of a USB drive failure on my mirrored freenas-boot. At the same time, my system-dataset (also on mirrored USB drives) failed. This has not been a great start to the year.
I have created a fresh freenas-boot pair (11.1-U6.3) on fresh USBs via a config backup (which I believe included the password seed). I have created a fresh system-dataset on a single USB (I have an SSD I intend to use for this purpose, _after_ I have recovered my main volume).
I have an encrypted volume, vol1, that I now cannot import after a reboot. AFAIK there's no issue with the disks themselves or the data stored within.
The UI tells me:
I have a monitor plugged in, and it tells me:
(Can't tell if there's a line break after the vol1 or whether that's the screen wrapping).
In a shell, basic diagnosis (and, I'm not highly familiar with which commands to run, but very willing to learn):
Based on some reading of the forum, it strikes me as likely that the IDs have changed, so I will need to do a permutation of.
The user-guide, 8.1.6, suggests the same - I should be importing a volume. When I go to that option, choose "decrypt disks" and proceed, the next page gives me no disks in the multi-select. Screenshot:
I'm sufficiently unfamiliar that I'd like to check how to proceed first, since clearly I don't want to hose my data.
The UI tells me:
Environment: Software Version: FreeNAS-11.1-U6.3 (35cbff5a1) Request Method: POST Request URL: http://orion.local/storage/volume/1/unlock/?X-Progress-ID=c6115303-6101-4bb4-89d0-d35d18faa0e0 Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/storage/views.py" in volume_unlock 1033. form.done(volume=volume) File "./freenasUI/storage/forms.py" in done 2870. raise MiddlewareError(msg) Exception Type: MiddlewareError at /storage/volume/1/unlock/ Exception Value: [MiddlewareError: Volume could not be imported: 4 devices failed to decrypt]
{timestamp} wsgi: [middleware.notifier:2547] Importing vol14795237512355458676 failed with: cannot import '147925237512355458676': no such pool available
[root@orion ~]# zpool status
  pool: dotsys-green
 state: ONLINE
  scan: none requested
        NAME                                          STATE     READ WRITE CKSUM
        dotsys-green                                  ONLINE       0     0     0
          gptid/a3423cdb-1742-11e9-8ce0-d05099c0adce  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
        freenas-boot  ONLINE       0     0     0
          mirror-0  ONLINE       0     0     0
            da0p2   ONLINE       0     0     0
            da1p2   ONLINE       0     0     0
[root@orion ~]# zpool list
NAME           SIZE  ALLOC   FREE  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
dotsys-green  12.5G  7.68M  12.5G         -     0%     0%  1.00x  ONLINE  /mnt
freenas-boot  28.5G   797M  27.7G         -      -     2%  1.00x  ONLINE  -
zpool import
