Thank you for any help with this.
Recently I update to 11.2 beta and then I was not able to boot my machine.
I "upgraded" to 11.1 u 6, everything appears to be fine however when I open the web interface I get the following message when I open the System tab.
Environment:
Software Version: FreeNAS-11.1-U6 (caffd76fa)
Request Method: GET
Request URL: https://192.168.1.10/system/
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py" in execute
64. return self.cursor.execute(sql, params)
File "./freenasUI/freeadmin/sqlite3_ha/base.py" in execute
412. execute = self.locked_retry(Database.Cursor.execute, query, params)
File "./freenasUI/freeadmin/sqlite3_ha/base.py" in locked_retry
389. rv = method(self, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/system/views.py" in home
685. tabs = appPool.hook_app_tabs('system', request)
File "./freenasUI/freeadmin/apppool.py" in hook_app_tabs
61. return self._get_array('hook_app_tabs', name, request)
File "./freenasUI/freeadmin/apppool.py" in _get_array
27. method(arr, func(*args, **kwargs))
File "./freenasUI/system/hook.py" in hook_app_tabs_system
71. obj = model.objects.order_by('-id')[0]
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __getitem__
295. return list(qs)[0]
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __iter__
256. self._fetch_all()
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in _fetch_all
1087. self._result_cache = list(self.iterator())
54. results = compiler.execute_sql()
File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py" in execute_sql
835. cursor.execute(sql, params)
File "/usr/local/lib/python3.6/site-packages/django/db/utils.py" in __exit__
94. six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/lib/python3.6/site-packages/django/utils/six.py" in reraise
685. raise value.with_traceback(tb)
Exception Type: OperationalError at /system/
Exception Value: no such column: system_advanced.adv_consolescreensaver
