intavg
- Mar 13, 2023
I am fairly new to TrueNAS and have been experimenting with jails and vms. I have two data pools, the smaller of which is called "VMPool" which is where the iocage dataset was created, and where I put all of the datasets related to VMs, such as iso images.
I want to replace VMPool with a new pool that will have much larger drives. I have deleted all of the plugins, jails and virtual machines, and I have deleted all of the other datasets in VMPool. However, when I try to delete the iocage dataset, I get the following error:
[EFAULT] Failed to delete dataset: cannot unmount '/mnt/VMPool/iocage/releases/13.1-RELEASE/root': pool or dataset is busy cannot unmount '/mnt/VMPool/iocage/releases/13.1-RELEASE': pool or dataset is busy cannot unmount '/mnt/VMPool/iocage/releases': pool or dataset is busy cannot unmount '/mnt/VMPool/iocage': pool or dataset is busy
What do I need to do to release whatever file is being locked so that I can remove the pool?
