zerothaught
- Jan 1, 2024
Are there any specific ports besides 443 that need to be opened for automatic updates? Upon selecting the option I get the following error message:
Cannot connect to host update.ixsystems.com:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1123)')]: Automatic update check failed. Please check system network settings.
I have confirmed that I have my gateway and default route set properly. My timezone is set to UTC in my BIOS and OS and can be confirmed by using the date command. I also get the following message when running wget update.ixsystems.com
ERROR: The certificate of 'update.ixsystems.com' is not trusted
ERROR: The certificate of 'update.ixsystems.com' doesn't have a known issuer
Is there a CA I need to install to get this working? I have dug through ~20 forums posts and most just say it's a timeserver issue.
Thanks
Thanks
