Good evening
If I try to create a volume using the Volume Manager, I get SCSI Errors (if someone is interested for the errors, I listed them below).
I would like to use this problem to get in touch with FreeNAS source and to debug this problem.
In the backend, there are useful log messages written to ${LOGOUT}.
So I just have one question :):
Do I have to assign a file to ${LOGOUT} or is there a default logfile already assigned?
Thanks a lot for any help,
kind regards,
Thomas
Just in case someone is interested: if I use the FreeNAS Volume Manager to create a new zfs volume on my Adaptec HBA with only one SSD attached I get the following log informations:
da0 at pmspcbsd0 bus 0 scbus0 target 0 lun 0
da0: <ATA INTEL SSDSC2BW24 DC32> Fixed Direct Access SCSI-5 device
da0: Serial Number PHDA438604NW2403GN
da0: 600.000MB/s transfers
da0: Command Queueing enabled
da0: 228936MB (468862128 512 byte sectors: 255H 63S/T 29185C)
da0: quirks=0x8<4K>
(da0:pmspcbsd0:0:0:0): ATA TRIM failed, disabling BIO_DELETE
(da0:pmspcbsd0:0:0:0): ATA COMMAND PASS THROUGH(16). CDB: 85 0d 06 00 01 00 01 00 00 00 00 00 00 40 06 00
(da0:pmspcbsd0:0:0:0): CAM status: SCSI Status Error
(da0:pmspcbsd0:0:0:0): SCSI status: Check Condition
(da0:pmspcbsd0:0:0:0): SCSI sense: ILLEGAL REQUEST asc:24,0 (Invalid field in CDB)
(da0:pmspcbsd0:0:0:0): Command byte 0 bit 0 is invalid
(da0:pmspcbsd0:0:0:0): Error 22, Unretryable error
kind regards,
Thomas
da0: quirks=0x8<4K>
