SOLVED TrueNAS(Web, SSH, NFS Share) all locking up sporadically
seanmcg182
To start, my system:
AsRock B450M Pro 4 Motherboard
AMD Ryzen 2700X CPU
32GB 3200MHz RAM
LSI SAS 9210 IT-Mode (Passed Through to TrueNAS)
3x8TB Toshiba X300 HDDs (Connected to SAS Card)
256GB HP EX920 NVMe SSD
Metal OS:
ESXi v6.7.0 Update 3
Install ISO was modified to include functioning Realtek Drivers, and NVME Driver from 6.5.0 (6.7 did not support my NVME by default)
VMs: (All VM Boot Drives are on the 256GB NVME Drive)
TrueNAS - 4 CPU Cores - 16GB RAM
Linux - 4 CPU Cores - 2GB RAM - Running SABnzbd
Linux - 4 CPU Cores - 2GB RAM - Running qBittorrent
Linux - 2 CPU Cores - 1GB RAM - Running Sonarr
Linux - 2 CPU Cores - 1GB RAM - Running Radarr
Linux - 2 CPU Cores - 1GB RAM - Running Lidarr
Linux - 2 CPU Cores - 1GB RAM - Running Plex
Windows - 4 - CPU Cores - 4GB RAM - Used for Remote Desktop to control server while travelling for work.
Linux VMs:
Have NFSCommon installed
Have this in fstab:
192.168.1.241:/mnt/RAID-Z-1/Media /mediaplex nfs auto,nofail,noatime,nolock,intr,tcp,actimeo=1800 0 0
I got that line of settings from my friend who helped me setup the server.
TrueNAS:
TrueNAS-12.0-U2
3x8TB Drives in RAIDZ1 configuration.
truenas% zpool status
pool: RAID-Z-1
state: ONLINE
scan: scrub repaired 0B in 06:02:56 with 0 errors on Tue Feb 23 07:19:56 2021
NAME STATE READ WRITE CKSUM
RAID-Z-1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/2a944cf6-63fa-11eb-8aac-000c29d59c77 ONLINE 0 0 0
gptid/2ea55fc0-63fa-11eb-8aac-000c29d59c77 ONLINE 0 0 0
gptid/302ca57e-63fa-11eb-8aac-000c29d59c77 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:02 with 0 errors on Fri Mar 12 03:45:02 2021
boot-pool ONLINE 0 0 0
da0p2 ONLINE 0 0 0
truenas% ifconfig
vmx0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:0c:29:69:08:7c
inet 192.168.1.241 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
truenas% zpool iostat
capacity operations bandwidth
pool alloc free read write read write
RAID-Z-1 12.4T 9.37T 122 262 4.80M 9.57M
boot-pool 1.16G 18.3G 0 0 2.65K 115
Not sure whatsup with my Alloc and Free, because my Pool size is 8.29TiB (59%) Used with 5.78TiB Free... I know, usage is getting a bit higher, but I don't think this is my issue, bear with me until the end.
The Pool currently has Encryption Enabled, Sync Disabled, Atime Off, Compression Level LZ4, ZFS Deduplication ON
On the Pool I have an SMB Share, and an NFS Share.
The NFS Share has Mapall User as Root, and Mapall Group as Wheel, and all of my VM 192.168 IP addresses.
I can successfully access the share on my VMs (With the exception described in the issue further below)
Two of the Hard Drives do show an intermittent Parameter 7 SMART failure, however, this has been confirmed to be a Firmware Bug, as the RAW Value is still showing 0. I've been in contact with Toshiba about it, and I am probably going to Replace the drives when I get back from my business trip... However again, I do not think that this is related.
The Parameter Value for both of the drives just slowly moves between 001 and 100, regardless of load.
Currently both drives are reading at 85+ out of 100, which is a good value, and the Failure flag states IN_THE_PAST.... and if I had to guess, within 48 hours, it'll cycle down to 1 and back up to 100 again.
Ouput of of of the drives for reference:
truenas% sudo smartctl -a /dev/da3
Password:
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: TOSHIBA HDWR180
Serial Number: 8040A13HFBLG
LU WWN Device Id: 5 000039 a58c90823
Firmware Version: 0603
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Mar 18 11:43:54 2021 EDT
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Self-test execution status: ( 73) The previous self-test completed having
a test element that failed and the test
element that failed is not known.
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 830) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 7717
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 149
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 088 001 050 Pre-fail Always In_the_past 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1117
10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 43
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 36
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 149
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 41 (Min/Max 22/54)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 001 001 000 Old_age Always - 67436740
222 Loaded_Hours 0x0032 098 098 000 Old_age Always - 952
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 525
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: unknown failure 90% 499 0
# 2 Extended offline Completed: unknown failure 90% 436 0
# 3 Short offline Completed: unknown failure 90% 435 0
# 4 Short offline Completed: unknown failure 90% 435 0
# 5 Short offline Completed: unknown failure 60% 435 0
# 6 Short offline Completed: unknown failure 90% 434 0
# 7 Short offline Completed: unknown failure 90% 433 0
# 8 Short offline Completed: unknown failure 90% 433 0
# 9 Extended offline Completed without error 00% 143 -
#10 Short offline Completed without error 00% 19 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The ISSUE:
Occassionally (every 3-15 minutes), TrueNAS will Kinda half-ass respond. Settings won't update or save on the web GUI... But if I try reloading the Web GUI, I get a notification that TrueNAS is non responsive or something.
During this time if I try to do an SSH Command (If I already have an SSH Window Open) it will hang and just give me a blank line until TrueNAS Comes back up.
If I try to Open an SSH Connection, it just times out and doesn't connect.
ALL of my Linux VM's that have the NFS Share Mounted stop downloading and report something along the lines of this SAMPLE taken from DMESG:
[82124.341719] rpc_check_timeout: 14 callbacks suppressed
[82124.341721] nfs: server 192.168.1.241 not responding, still trying
[82124.342003] nfs: server 192.168.1.241 not responding, still trying
[82124.342209] nfs: server 192.168.1.241 not responding, still trying
[82124.342376] nfs: server 192.168.1.241 not responding, still trying
[82124.342586] nfs: server 192.168.1.241 not responding, still trying
[82124.342842] nfs: server 192.168.1.241 not responding, still trying
[82124.343057] nfs: server 192.168.1.241 not responding, still trying
[82124.343236] nfs: server 192.168.1.241 not responding, still trying
[82194.158268] nfs: server 192.168.1.241 not responding, still trying
[82194.159231] nfs: server 192.168.1.241 not responding, still trying
[82194.159547] nfs: server 192.168.1.241 not responding, still trying
[82194.159810] nfs: server 192.168.1.241 not responding, still trying
[82194.160050] nfs: server 192.168.1.241 not responding, still trying
[82194.160093] nfs: server 192.168.1.241 not responding, still trying
[82194.162363] nfs: server 192.168.1.241 not responding, still trying
[82194.162636] nfs: server 192.168.1.241 not responding, still trying
[82194.162838] nfs: server 192.168.1.241 not responding, still trying
[82194.163054] nfs: server 192.168.1.241 not responding, still trying
[82194.565804] nfs: server 192.168.1.241 OK
[82194.565839] nfs: server 192.168.1.241 OK
[82194.565890] nfs: server 192.168.1.241 OK
[82194.565934] nfs: server 192.168.1.241 OK
[82194.565977] nfs: server 192.168.1.241 OK
[82194.676875] nfs: server 192.168.1.241 OK
[82194.676942] nfs: server 192.168.1.241 OK
[82194.676989] nfs: server 192.168.1.241 OK
[82194.677074] nfs: server 192.168.1.241 OK
[82194.677098] nfs: server 192.168.1.241 OK
[82477.600634] rpc_check_timeout: 855 callbacks suppressed
[82477.600637] nfs: server 192.168.1.241 not responding, still trying
[82477.600646] nfs: server 192.168.1.241 not responding, still trying
[82477.600649] nfs: server 192.168.1.241 not responding, still trying
[82477.600651] nfs: server 192.168.1.241 not responding, still trying
[82477.600653] nfs: server 192.168.1.241 not responding, still trying
[82477.600654] nfs: server 192.168.1.241 not responding, still trying
[82482.976660] nfs: server 192.168.1.241 not responding, still trying
[82492.448701] nfs: server 192.168.1.241 not responding, still trying
[82498.336995] nfs: server 192.168.1.241 not responding, still trying
[82498.337007] nfs: server 192.168.1.241 not responding, still trying
[82498.337009] nfs: server 192.168.1.241 not responding, still trying
[82498.337012] nfs: server 192.168.1.241 not responding, still trying
[82498.337014] nfs: server 192.168.1.241 not responding, still trying
[82498.337017] nfs: server 192.168.1.241 not responding, still trying
[82508.576980] nfs: server 192.168.1.241 not responding, still trying
[82508.576992] nfs: server 192.168.1.241 not responding, still trying
[82512.416902] nfs: server 192.168.1.241 not responding, still trying
[82518.817067] nfs: server 192.168.1.241 not responding, still trying
[82537.070934] nfs: server 192.168.1.241 not responding, still trying
[82537.071047] nfs: server 192.168.1.241 not responding, still trying
[82537.071074] nfs: server 192.168.1.241 not responding, still trying
[82537.071097] nfs: server 192.168.1.241 not responding, still trying
[82537.071122] nfs: server 192.168.1.241 not responding, still trying
[82537.071166] nfs: server 192.168.1.241 not responding, still trying
[82537.071322] nfs: server 192.168.1.241 not responding, still trying
[82537.071346] nfs: server 192.168.1.241 not responding, still trying
[82537.071347] nfs: server 192.168.1.241 not responding, still trying
[82537.071367] nfs: server 192.168.1.241 not responding, still trying
[82586.760305] call_decode: 1008 callbacks suppressed
[82586.760309] nfs: server 192.168.1.241 OK
[82586.760851] rpc_check_timeout: 6 callbacks suppressed
[82586.760852] nfs: server 192.168.1.241 not responding, still trying
[82586.761003] nfs: server 192.168.1.241 not responding, still trying
[82586.761058] nfs: server 192.168.1.241 not responding, still trying
[82586.761102] nfs: server 192.168.1.241 not responding, still trying
[82586.761104] nfs: server 192.168.1.241 OK
[82586.761156] nfs: server 192.168.1.241 not responding, still trying
[82586.761212] nfs: server 192.168.1.241 not responding, still trying
[82586.761295] nfs: server 192.168.1.241 not responding, still trying
[82586.761349] nfs: server 192.168.1.241 not responding, still trying
[82586.761353] nfs: server 192.168.1.241 OK
[82586.761480] nfs: server 192.168.1.241 not responding, still trying
[82586.761541] nfs: server 192.168.1.241 not responding, still trying
[82586.761546] nfs: server 192.168.1.241 OK
[82586.762623] nfs: server 192.168.1.241 OK
[82586.763058] nfs: server 192.168.1.241 OK
[82586.763199] nfs: server 192.168.1.241 OK
[82586.766013] nfs: server 192.168.1.241 OK
[82586.766914] nfs: server 192.168.1.241 OK
[82586.767514] nfs: server 192.168.1.241 OK
TrueNAS Debug file if it helps:
https://drive.google.com/file/d/1_1fIuBnpCRP4jHI_E-ckKxnZDneFtsfC/view?usp=sharing
Sorry for infodump, but figured the more information, the better!
If anyone has any other tests they'd like me to run, just ask.
seanmcg182
The specific Error Message the TrueNAS Web GUI shows is "Connecting to TrueNAS... Make sure the TrueNAS system is powered on and connected to the network. "
This can sometimes resolve in 2 minutes, sometimes 20... but it is always annoying.
HoneyBadger
actually does care
Administrator
Is this enabled at the pool level? If so, there's your likely problem.
Dedup is extremely memory hungry to the (estimated) degree of 5GB per 1TB, and you have 5TB of data written.
Run zpool status -D poolname and look for the line that says "DDT entries X, size in core Y, size on disk Z"
Multiple the "number of entries" by the "size in core" and that's the RAM in bytes that you're using just to support your deduplication table.
seanmcg182
dedup: DDT entries 73644195, size 869B on disk, 210B in core
So 73,644,195 * 869 = 63,996,805,455 ~ 63GB? Did I do that correctly?
I suppose when I remake my pool when I replace my drives, I can disabled dedup. I only had it on becaue the friend who helped me initially set everything up recommended it...
Question:
Based on this table here, how much space is Dedup saving me? Not really sure how to decipher it
bucket allocated referenced
______ ______________________________ ______________________________
refcnt blocks LSIZE PSIZE DSIZE blocks LSIZE PSIZE DSIZE
1 70.2M 8.76T 8.69T 8.68T 70.2M 8.76T 8.69T 8.68T
2 16.8K 2.05G 1.79G 1.80G 34.7K 4.23G 3.66G 3.68G
4 2.92K 363M 277M 280M 14.3K 1.73G 1.33G 1.34G
8 583 68.3M 25.8M 26.5M 5.95K 716M 245M 253M
16 155 18.0M 1.71M 1.94M 3.24K 385M 34.1M 39.1M
32 107 13.1M 937K 1.06M 4.71K 594M 40.7M 47.2M
64 30 3.38M 110K 160K 2.58K 302M 9.54M 13.7M
128 15 1.88M 60K 79.9K 2.63K 336M 10.5M 14.0M
256 1 128K 4K 5.33K 292 36.5M 1.14M 1.52M
1K 2 256K 8K 10.7K 2.38K 304M 9.51M 12.7M
2K 5 640K 20K 26.6K 11.2K 1.40G 44.8M 59.7M
Total 70.2M 8.77T 8.69T 8.68T 70.3M 8.77T 8.69T 8.69T
I think its saying I'm only saving about 0.08-0.09TB... so 80-90GB... is this correct? If so, its almost entirely not orth it for my use case lol
EDIT: Adding picture of CLI output because the text editor warped the paste
HoneyBadger
actually does care
Administrator
You want to use 73,644,195 * 210 (the "core" size) but that still yields 15,465,280,950 = 14.4GB of RAM just for deduplication.
You owe that friend a swift kick in the butt. :tongue:
Bingo. The vast majority of your blocks have a refcnt of 1 - in that they're unique and are getting zero benefit from deduplication.
Back up everything, destroy and recreate the pool, and restore it. You'll be set again after that.
seanmcg182
:tongue:
I should be getting my new drives on Sunday, and will start Migrating over to the new pool. I'll respond here again once I've done that and see if I still have issues. No point in using the same disks rn as I'm RMA'ing them anyways due to the bogus SMART messages lol
Thanks for the advice!
seanmcg182
Sorry for the delay... While installing the new drives, I somehow fried my PSU and one of the new drives... honestly not sure what happened.... turned on server, and new hard drive smoked.
Anyways, finally got the new PSU, new hard drives in, and the data migrated over to the new pool (With Dedup off, Mirrored configuration), and have been operating for a couple days now.
Glad to say my issue has disappeared! Thank you for your support @HoneyBadger
HoneyBadger
actually does care
Administrator
Like all other electronics, hard drives run on magical blue smoke, and letting the smoke out causes them to fail. Sorry to hear that happened. (You weren't using any Molex-to-SATA adaptors, were you?)
Glad to hear it's working. Keep compression on and dedup off, set up scheduled scrubs and SMART tests, and may your pool live a long and healthy life!
seanmcg182
Nah, it was a normal PSU to 4x Sata Daisy Chain.
Compression isn't "off", but its set to the default LZ4, doesn't seem to be giving any issues.
And yup, scheduled scrubs and smart tests
