Hello forum,
I have some doubts regarding a new project I’m tackling at work this month.
We are running out of space on my old HP StoreVirtual SAN and I’m trying to figure out a budget minded solution to the problem in the topic title.
Basically what I have come up with is the following.
For the storage solution I wanted to go with TrueNAS, probably core because I don’t need anything exceedingly fancy like scaling out and stuff).
I spec’d out a head server in the form of a Supermicro CSE-829U X10DRU-i+ equipped with 2 x E5-2667V4 CPUs because we use Samba shares in the office and I know good single thread power is basically required if I want encryption, which I do. I added 256GB of ram (8 x 32GB DDR4) so I can have a good ARC capacity. The HBA will be either a 9305-16i or 9300-16i, the first is like 200€ more then the latter but I heard the silicon is newer and way more efficient so I’m still considering what to do.
I will connect a JBOD box to the head server in the form of a HP M6720 24 x 3.5" box.
In total I will have 36 x 3.5" bays at my disposal.
I wanted to populate them as follows:
32x 4TB Enterprise SAS HDD to form into a single pool of 4 x 8 wide RaidZ1s
2x 960GB SSD for metadata stuff to make everything a bit more snappy
2x 480GB SSD for L2ARC
I also wanted to add a 16 or 32GB optane ssd for SLOG.
Everything will be connected to my hosts via a pair of stacked Dell PowerConnect 8024F so all 10G links.
In the pool I wanted to have 2 datasets, one NFS for VMWare and one SMB for our windows data sharing stuff.
This is my plan at the moment.
I was also wondering about deduplication functionality but I have no idea what that would imply on the overall responsiveness of the system.
We normally have around 20 to 30 VMs active at any given time.
All the VMs run either Windows 10 or Windows Server 2019 or later.
My question to you experts is would this solution be satisfactory for 10 PLC software developers and maybe 3 or 4 power users?
I want the machines to feel snappy but as I said cash is… well… not a friend in this period.
The proposed solution would come in at a grand total of 6500€ or thereabouts.
Thanks in advance for any suggestions.
