jonathanalmstrom
- Feb 7, 2024
Hello all experts!
I have recently built a new computer that will serve as a server and virtualizition machine. It's built from mostly parts I had lying around (hence the probably not best components, but I hope it will work).
What I have is:
- Motherboard: ASRock Fatal1ty B450 Gaming-ITX/ac
- CPU: Ryzen 5600G
- Ram: Corsair 32GB (2x16GB) DDR4 3200MHz CL16
- PSU: Corsair CV650 650W Dual EPS
- m.2 ssd for OS
- 4x 6tb WD red CMR
First I used a m.2 -> sata adapter for adding more drives but it didn't work so I'm installing a regular m.2 SSD and my 4 drives directly on the motherboard (unless the m.2 slot shares a lane with one of the sata ports).
I will later on go for a lsi 9207-8i HBA when I need to add more drives.
I need help with the installation procedure and to chose OS (proxmox or truenas scale).
I have searched but didn't find very much info for my specific case. I have very limited spare time due to a long term sick child so Im doing this when everyone is sleeping in the night and would be very greatful for any guidance!
I am choosing between Proxmox or Truenas Scale with:
- Truenas Scale (if running proxmox)
- Plex server in LXC
- Frigate in LXC
- Home assistant OS
- linux OS for torrent client
What should I do?
As far as I can see, passing the LSI board to truenas should be fine if I run proxmox as my main OS? Is there any advantages with choosing either of the installation procedures?
Are there any issues with adding an LSI baord later on? What I can find I can use the LSI baord with SFF 8087 -> 4x sata cable splitter and add regular sata drives?
Best regards
Jonathan
What I have is:
- CPU: Ryzen 5600G
- m.2 ssd for OS
- 4x 6tb WD red CMR
- Frigate in LXC
- Home assistant OS
What should I do?
Best regards
Jonathan
