raskitoma
- Sep 28, 2018
Hi guys,
First of all, sorry for any typo or error, English is not my first language (Spanish is)
Version: TrueNAS-SCALE-21.08-BETA.1
Hardware: Just see my signature... everything is there
So right now I have a full working setup with: (I will always update this list accordingly)
My idea is to share my experience with all the migration, docker setups, etc. Even if a solution has been made available, sometimes for noobs it is really hard to find. Also most of the times people just want a simple explanation of how to do things. (For example how to solve many things on Caddy!)
So well guys, I'm gonna try to be available and read this post as much as I can so I can help you with any questions.
See ya!
Just take note that the way I implemented docker containers on my server is allowed by TrueNAS but it's not recommended by iX, if you don't handle carefully you can break something for sure.
Please refer to their Discord Server for more and proper support and use the official supported Truecharts.
sep 6th 2021:
may 4th 2021:
feb 2nd 2021:
I just switched from TrueNAS Core to SCALE. The idea was to take advantage of all the features that comes when you're using docker instead of jails(I love jails btw)
- I love the new panels on the dashboard, it helps to keeps things clear and tidy. The new Storage panel is more functional than including one for each pool.
- Thanks for the new Network panel!
- That's some fancy design on the login screen!
- The extra functionality on the pools section is awesome.
- Upgraded with 0 problems with my current docker configuration.
may 4th 2021:
- The gui update is really neat, but I must say, the cron options are better and makes more sense in the new section!
- I'm really happy to see that you have an easy way to list all containers, even those that I have installed using docker-compose command or portainer stack, etc.
feb 2nd 2021:
- Plex Media Server for media (migrated all the tiles/metadata/user_accounts/user_stats from jail to docker!!! created from scratch using Launch Docker Image button) - I'm already a PlexPass user
- Jellyfin
just for fun... it's nice to try something new as it does mostly the same as Plex, but for free.I'm using it as an alternative for some kind of media and for iptv manage (recording, etc. It's much better for this than Plex) XTEVE with xml auto updater (using Schedules Direct)Moved to another machine dedicated for thisdizqueTV - Put some series I have in Plex with commercials and created my own TV-Channel (this is actually fun when you see it working)Moved to the same machine as xteveYACReaderKomga for Comics- Calibre and Calibre-Web for Books
Subsonic for musicRight now I'm using Plex for music.- Ombi for requests
- Sonarr/Radarr/Lidarr/Bazarr/Mylar/LazyLibrarian for media management
- Jackett with Flaresolver
- Deluge
- Handbrake for autoenconding and optimization using HEVC
- Tautulli for Plex stats
- Nextcloud (not using the template provided by IX)
MineOS with 2 instances runningmove this to another machine2 Valheim dedicated server instancesgot rid of those... I'm not playing anymore... lol- Resilio Sync
- Wordpress
- Papermerge for doc organization (receipts, scans, etc)
Chevereto image galleryNot using it anymore!- MySQL, PostgreSQL, Mongo and Redis
HASS - Home automationMoved to araspberry pi 3the same machine where xteve is locatedI have with pihole and smokeping- Caddy - to manage redirects, proxy reverse, auth, etc.
- GoDaddyddns to auto register dynamic ip with domain
- Netbootxyz
Doublecommandernot using anymore, also was for testing purposes only... too dangerous to keep this alive!- Sqlite editor
- webtop for testing
- remmina (rdp/vnc web browser client)
- Kimai2 for time tracking - this is specially useful for remote working
OrganizrNot using it anymore!- Portainer for monitoring and testing(
I'm not gonna ever use it for deploy anythingI'm actually using it as an easy way to manage containers) - Netdata for monitoring.
APCUPSD(Moved to other machine(where xteve is), I didn't have time to deal with recompiling Maxlinear drivers)- WikiJS
- 1 small monero CPU mining instances activated via cron to run on specific times.
- 1 small nicehash CPU mining instance
- Multiple telegraf instances to fill up an...
- ...influx db
- Grafana instance
- Graylog
- Appsmith
- Machinaris, but I installed it using docker-compose, not the one our great guys from Truenas provided... I haven't saw it before... sorry!
- Folding@Home - 1 cpu, low power... Just to help with disease investigation efforts
- liquidctl - To control Corsair Pump and Fans via docker
- 2 x Watchtower instances: one notifies to my slack when there's an update available for all cointainers, other instance keeps some containers auto updated using flags(the ones I consider not critical) while notifying about the update operation.
See ya!
