TrueNAS Scale VNET Question
bigops
I have used VNETs in TrueNAS Core for years to split out network segments. Having a separate routing table for jails help to keep multiple jails isolated for each other which is important to route traffic over separate physical interfaces. Since the release of TrueNAS scale I was looking into possible migration to Scale since my org is a big Debian shop.
My question is if Scale has some capability like what is offered by VNET where we can have individual routing tables. Base debian has ipRoute2 which performs this function. What is the equivalent in TrueNAS scale and if so can it be tagged to a specific docker container?
BG
Whattteva
This is probably not what you're looking for, but direct DHCP from your existing LAN isn't supported under Docker without some kludgey hacks, which is not supported by the official Docker engine.
