Wolfeman0101
- Jun 14, 2012
My system has been running terrible all day and then I got an alert da2 was faulted with read and write errors but I ran a SMART test and it looks ok. Any ideas?
bkwolfe@Packers:~ % sudo smartctl -a /dev/da2 smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p2 amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: ST6000VN001-2BB186 Serial Number: ZCT2EAPF LU WWN Device Id: 5 000c50 0c5a8c8bb Firmware Version: SC60 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5425 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Jan 8 13:19:58 2021 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 712) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 081 064 006 Pre-fail Always - 120579295 3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 10 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 085 060 045 Pre-fail Always - 293983579 9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 3040 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 10 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 099 097 000 Old_age Always - 8590131207 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 065 050 040 Old_age Always - 35 (Min/Max 31/39) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 2 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 59 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 129 194 Temperature_Celsius 0x0022 035 050 000 Old_age Always - 35 (0 29 0 0 0) 195 Hardware_ECC_Recovered 0x001a 081 064 000 Old_age Always - 120579295 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 3035 (101 101 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 22621122402 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 174186156058 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 3040 - # 2 Short offline Completed without error 00% 3027 - # 3 Extended offline Completed without error 00% 3007 - # 4 Short offline Completed without error 00% 2931 - # 5 Short offline Completed without error 00% 2907 - # 6 Short offline Completed without error 00% 2883 - # 7 Short offline Completed without error 00% 2859 - # 8 Short offline Completed without error 00% 2835 - # 9 Short offline Completed without error 00% 2811 - #10 Short offline Completed without error 00% 2787 - #11 Extended offline Interrupted (host reset) 40% 2782 - #12 Short offline Completed without error 00% 2763 - #13 Short offline Completed without error 00% 2739 - #14 Short offline Completed without error 00% 2715 - #15 Short offline Completed without error 00% 2691 - #16 Short offline Completed without error 00% 2667 - #17 Short offline Completed without error 00% 2643 - #18 Extended offline Interrupted (host reset) 10% 2631 - #19 Short offline Completed without error 00% 2595 - #20 Short offline Completed without error 00% 2571 - #21 Short offline Completed without error 00% 2547 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. bkwolfe@Packers:~ %
