I've been using FreeNAS and TrueNAS products for my backup systems for a long time, and I am very satisfied. I have a question that I would like to ask but haven't dared to try. Can you help?
I have a Dell R740 18LFF model server. I've installed 18x10 TB SAS HDDs on this server, and there are also 4 x 6.4TB NVMe SSDs in the PCIe ports.
What I want to do is install VMware on the server and virtualize my customer virtual servers on NVMe SSDs while also virtualizing my system backups on the virtualized TrueNAS. I'm worried about whether I'll encounter any problems if I even set it up in HBA mode because disks presented from VMware won't work as HBA, and this concerns me. If I use hardware RAID with this usage scenario and add a non-mirrored disk on TrueNAS, would there be any security issues I should worry about? Or should I run the disks as non-RAID and present them to the system via VMware? My goal is not to achieve performance, as I am only concerned about security since I will be taking backups. Thanks to all friends who will help.
