lodzins194
- Sep 2, 2021
Hello! I am using TrueNAS Core 12.0-U5.1 on a DIY server and have been running into an issue- every time a file larger than 200MB is being copied from one folder on the server to another, GUI won't load and the server becomes unresponsive. After a hard reboot everything works again.
I have been experiencing said issue since May 2021. No plugins installed, the only services running are S.M.A.R.T. and SMB, no VMs. All overclocks, underclocks and power management settings have been turned off.
What could cause this issue? I will appreciate any suggestions.
System specs:
Motherboard: ASUS Prime H410M-E
CPU: Intel Core i3-10300 @ 3.70GHz
RAM: 2x 16GB (32 GB total) DDR4 non ECC
HDD: 2X WD Red 6TB in RAID 1
Thanks in advance!
System specs:
Thanks in advance!
