TrueNAS CORE 12.0-U8.1 Released
eturgeon
Super Moderator
awasb
Trying to update, but can't reach host
Unable to connect to url https://update-master.ixsystems.com/TrueNAS/TrueNAS-12.0-STABLE/LATEST: Automatic update check failed. Please check system network settings.
root@NAS-1[~]# ping google.com
PING google.com (142.250.64.174): 56 data bytes
64 bytes from 142.250.64.174: icmp_seq=0 ttl=117 time=5.820 ms
64 bytes from 142.250.64.174: icmp_seq=1 ttl=117 time=5.642 ms
^C
--- google.com ping statistics ---
2 packets transmitted, 2 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 5.642/5.731/5.820/0.089 ms
root@NAS-1[~]# ping https://update-master.ixsystems.com
ping: cannot resolve https://update-master.ixsystems.com: Unknown host
root@NAS-1[~]# ping http://update-master.ixsystems.com
ping: cannot resolve http://update-master.ixsystems.com: Unknown host
NugentS
If its any help - I managed
Jailer
Not strong, but bad
Tony-1971
I can ping it:
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@freenas-sm[~]# ping update-master.ixsystems.com
PING update-master.freenas.org (192.41.228.50): 56 data bytes
64 bytes from 192.41.228.50: icmp_seq=0 ttl=37 time=142.768 ms
64 bytes from 192.41.228.50: icmp_seq=1 ttl=37 time=141.672 ms
anodos
Sambassador
Successfully applied to 5 U8 systems with no issues so far. YMMV
Primary concern will be for AFP users. If AFP client gets unexpectedly disconnected, then check for core files. Due to changes related to CVE we call netatalk_panic() in cases where adouble metadata is malformed in a potentially dangerous way. It's somewhat hard to test all the edge cases for this (especially with old data / clients). Generally speaking, it's better to begin the migration process off of AFP.
was able to get on system updated to U8.1
second system not able to reach server
root@NAS-2[~]# ping update-master.ixsystems.com
64 bytes from 192.41.228.50: icmp_seq=0 ttl=47 time=44.126 ms
64 bytes from 192.41.228.50: icmp_seq=1 ttl=47 time=43.576 ms
^C
--- update-master.freenas.org ping statistics ---
round-trip min/avg/max/stddev = 43.576/43.851/44.126/0.275 ms
root@NAS-2[~]# ping google.com
PING google.com (142.250.217.174): 56 data bytes
64 bytes from 142.250.217.174: icmp_seq=0 ttl=117 time=6.757 ms
64 bytes from 142.250.217.174: icmp_seq=1 ttl=117 time=6.602 ms
^C
round-trip min/avg/max/stddev = 6.602/6.679/6.757/0.078 ms
darylk
Installed this last night. Plugins not working. Dropped to community and tried to install any of them and received "release 12.2 not found". Issuing a "pkg update" in the shell gave a bunch of errors as well so....... First time trying truenas core. Before reaching this deal breaker I also wasnt able to bind network cards, 2 port intel nic card. Same technique that worked last night on truenas-scale. Scale screwed up SSL so I tried core. Off to another pasture.
Nordlicht-13
Update stays at:
Update
66.67%
Installing base-os (1/3)
Under System->Boot I already got listed several entrys:
Boot Environments
Name / Active / Created / Space / Keep
12.0-U8.1 / - / 2022-04-18 21:04:00 / 653.98 MiB / no
12.0-U8.1-1 / - / 2022-04-18 21:23:00 / 1.17 GiB / no
12.0-U8.1-2 / - / 2022-04-19 02:23:00 / 1.20 GiB / no
12.0-U8.1-3 / Reboot / 2022-04-19 15:35:00 / 1.20 GiB / no
12.0-U8.1-4 / - / 2022-04-20 00:29:00 / 665.97 MiB / no
default / Now / 2022-02-18 23:41:00 / 410.00 KiB
Initial-Install / - / 2022-02-23 13:45:00 / 9.65 MiB / yes
1 - 7 of 7
Kartoffel
Warning: If you need AFP on maybe older mac's wait! I get a lot of this problems:
kernel: pid 4846 (afpd), jid 0, uid 1001: exited on signal 6​
pid is counting every 5 seconds. No way to work with. Rollback to 12.0 U8 solved it temporary. I hope U8.2 fix the problem.:smile:
anodos
Sambassador
The problem was caused by a buggy CVE fix upstream. I fixed several issues with it before U8.1 release, but obviously there is some edge case I missed.
Is where I've fixed the initial issues with AFP. If you are using AFP in a production environment / place of work. Do not roll back without thoroughly understanding the consequences of this. The AFP vulnerabilities are IIRC unauthenticated remote code execution as root. This is not something to leave exposed at your place of work :)
This means, that I need some user who is having this crash (I can't reproduce the crash) provide me with clear instructions on how to reproduce the issue. It will not get fixed until this happens.
With that said, people using AFP should migrate to SMB already. :)
Kartoffel
Thank you for your fast feedback, anodos. i am glad to hear that the problem is being addressed.
Using 8.1 is no option because the whole computer becomes unusable when connected to TrureNAS.
