TrueNas Cobia rls 23.10.0.1 Fails to find Network Card
kulbir
I am using TRUNAS Cobia Nightly, I have two issues, any help will be appreciated:
OperationName
UpgradeTrueNAS-23.10-MASTER-20231109-042812 -> TrueNAS-23.10-MASTER-20231116-033818
Check Release Notes
Situation 1: Can not upgrade Nightlies any more fails with the following Message
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 943, in alert_source_clear_run raise CallError(f"Alert source {name!r} not found.", errno.ENOENT) middlewared.service_exception.CallError: [ENOENT] Alert source 'HasUpdate' not found.
Situation 2:
I thought I would update my server to 23.10.0.1, system loads what the network interface fails to connect And on CLI I read web interface is not available
kulbir
my card info while booted in Nightly as stated above is as follows
root@truenas:~# ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 1xx.xx.xx.xxx netmask 255.255.255.0 broadcast 172.16.1.255
ether xx;xx;xx;xx;xx;xx txqueuelen 1000 (Ethernet)
RX packets 1100 bytes 168981 (165.0 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 519 bytes 100013 (97.6 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xfe700000-fe720000
NugentS
At the top of the forum page is a "Forum Rules". The most important of these is that you have to post your hardware so we have some idea what you are talking about.
kulbir
what will be the command to get hw config that i can load here I have attached a a capture from LSCPU command
Thanks
  • LSCpu output.txt
NugentS
There isn't one.
Just list your hardware please - have a look at my signature for ideas of what is needed
kulbir
I have an American Trend bios server 2ith 8 G RAM and 4 HDDs in raid format server has two network cards. I only use 1 network card
kulbir
in past I use to use "HWinfo" to list the hw but that is not working anymore
NugentS
@kulbir try again - please post your hardware, not some abstract almost useless sentence. Again - look at my signature for a guide
kulbir
I am having hard time providing the info youi are requesting here is another tryu
Primary NAs
Model name: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
BIOS Model name: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz CPU @ 3.1GHz
Ram ; 8 G
Network : 2 ports 1G each
Storage:
1 Pool RAIDZ1 4 Drives
#1 WD-WMAZA3902380 1.82 TiB
Model: WDC_WD20EARS-00MVWB0
Transfer Mode: Auto
Rotation Rate (RPM):N/A
HDD Standby:ALWAYS ON
Adv. Power Management:DISABLED
Enable S.M.A.R.T.: true
S.M.A.R.T. extra options: N/A
#2 W520VK6Z 1.82 TiB
Model: ST2000VN000-1HJ164
Transfer Mode:Auto
Rotation Rate (RPM):5900
HDD Standby: ALWAYS ON
Adv. Power Management: DISABLED
#3 WD-WX32DC1P0XVN 3.64 TiB
Model: WDC_WD40EFZX-68AWUN0
Transfer Mode: Auto
Rotation Rate (RPM): 5400
#4 W520VJ53 1.82 TiB
Transfer Mode: Auto
Rotation Rate (RPM): 5900
1 Boot Drive
WD-WCAV24676434 298.09 GiB boot-pool
So about that network card...
If you have this little of an idea of what hardware you're using, you probably don't have any business running Nightly code--can it really have not been obvious to you that the type of network device you have would be critical to helping you here? And yet, after six of your posts in this thread, none of us have any idea what motherboard or network interface you're using. Even after you've been asked repeatedly for this information.
NugentS
yeah - I am out
kulbir
Thanks every one trying to help finaly found a command to read what card I have and here is capture
