60+ emails today for "Failed to get properties: Transport endpoint is not connected"
ctag
I'm curious if anyone else has seen this. Today I've been getting clusters of alert emails from my server every hour or so.
New alerts:
  • Failed to get properties: Transport endpoint is not connected
Current alerts:
  • Failed to check for alert NTLMv1Authentication: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 808, in __run_source alerts = (await alert_source.check()) or [] ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/alert/source/smb.py", line 76, in check if not await self.middleware.call('service.started', 'cifs'): ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service.py", line 201, in started state = await service_object.get_state() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service_/services/base.py", line 37, in get_state return await self.middleware.run_in_thread(self._get_state_sync) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1254, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service_/services/base.py", line 42, in _get_state_sync state = unit.Unit.ActiveState ^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/pystemd/base.py", line 191, in _call return func(self, name, *args) ^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/pystemd/base.py", line 128, in _get_property return bus.get_property( ^^^^^^^^^^^^^^^^^ File "pystemd/dbuslib.pyx", line 482, in pystemd.dbuslib.DBus.get_property pystemd.dbusexc.DBusTimeoutError: [err -110]: b'Connection timed out'
  • Failed to check for alert SMBLegacyProtocol: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 808, in __run_source alerts = (await alert_source.check()) or [] ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/alert/source/smb.py", line 53, in check if not await self.middleware.call('service.started', 'cifs'): ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service.py", line 201, in started state = await service_object.get_state() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service_/services/base.py", line 37, in get_state return await self.middleware.run_in_thread(self._get_state_sync) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1254, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service_/services/base.py", line 40, in _get_state_sync unit = self._get_systemd_unit() ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service_/services/base.py", line 68, in _get_systemd_unit unit.load() File "/usr/lib/python3/dist-packages/pystemd/base.py", line 90, in load unit_xml = self.get_introspect_xml() ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/pystemd/base.py", line 75, in get_introspect_xml bus.call_method( File "pystemd/dbuslib.pyx", line 446, in pystemd.dbuslib.DBus.call_method pystemd.dbusexc.DBusTimeoutError: [err -110]: b'Connection timed out'
ctag
Alerts continue. Rebooting the whole system this morning didn't help.
This is on TrueNAS-SCALE-23.10.1.3.
Searching for "Transport endpoint is not connected" returns a lot of results for systemd, but I don't see anything directly related to Truenas.
