Failed to check for alert BootPoolStatus
jlmr
After upgrading to TrueNAS-SCALE-22.02-RC.2 within a day or so I started to get alerts on this and next minute I get an all clear.
Here is the message I receive. Also, I have received alerts about a pool off-line and then it will come right back on-line but i dont get any message like the boot-pool.
I do have 2 servers running and both have pushed out this error.
New alerts:
  • Failed to check for alert BootPoolStatus: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 97, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 33, in _call with Client('ws+unix:///var/run/middlewared-internal.sock', py_exceptions=True) as c: File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 317, in __init__ self._ws.connect() File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 126, in connect rv = super(WSClient, self).connect() File "/usr/lib/python3/dist-packages/ws4py/client/__init__.py", line 222, in connect bytes = self.sock.recv(128) socket.timeout: timed out """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 773, in __run_source alerts = (await alert_source.check()) or [] File "/usr/lib/python3/dist-packages/middlewared/alert/source/boot_pool.py", line 16, in check pool = await self.middleware.call("zfs.pool.query", [["id", "=", boot_pool]]) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1324, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1289, in _call return await self._call_worker(name, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1295, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1218, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1192, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) socket.timeout: timed out
Current alerts:
1 minute later
The following alert has been cleared:
Kris Moore
SVP of Engineering
Administrator
That seems like some sort of bug, please file a ticket on https://jira.ixsystems.com and attach a debug file (System -> Advanced -> Download Debug). We'll take a look and see if that can be fixed for the final release.
