hello all
i updated to the last update truenas scale and now i have this error:
any sugestion?????
CRITICAL
Failed to check for alert Quota: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 114, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 33, in _call with Client('ws+unix:///var/run/middlewared-internal.sock', py_exceptions=True) as c: File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 315, in __init__ self._ws.connect() File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 126, in connect rv = super(WSClient, self).connect() File "/usr/lib/python3/dist-packages/ws4py/client/__init__.py", line 222, in connect bytes = self.sock.recv(128) socket.timeout: timed out """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 773, in __run_source alerts = (await alert_source.check()) or [] File "/usr/lib/python3/dist-packages/middlewared/alert/base.py", line 222, in check return await self.middleware.run_in_thread(self.check_sync) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1172, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/alert/source/quota.py", line 37, in check_sync datasets = self.middleware.call_sync("zfs.dataset.query_for_quota_alert") File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1328, in call_sync return self.run_coroutine(self._call_worker(name, *prepared_call.args)) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_coroutine return fut.result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 433, in result return self.__get_result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 389, in __get_result raise self._exception File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1271, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1186, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) socket.timeout: timed out
2022-05-07 19:03:56 (Europe/Lisbon)any sugestion?????
