TrueNAS 12.2 DNS problem
yamaharacer
Hi i have a realy strange problem with DNS on my build.
Hardware:
Supermicro x11scl-f
32GB ecc Ram DDR4
Intel Core i3 9100
4x4TB WesternDigital plus
I have set whole network to static settings.
Problem is that in shell of Truenas I cant ping every homepage but on my desktop with same settings I can.
There is also a problem in setting up VMs and plugins/Jails:
On some plugins/Jails when I set static IP to and want to install, it has problems to reach pkg.freebsd.org to get the packages. It seems that it cant reach because of DNS failure. Its not every only some dont work.
When I change to installation of plugin to DHCP I cant install. Plugins/Jails and VMs need static IPs otherwise it ends up in errors.
for example:
Error: adguard1 had a failure Exception: RuntimeError Message: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped adguard1 due to DHCP failure Partial plugin destroyed
Also wanted to install a VM. While installation DHCP doesnt work so I set up static. Works except for some connections, for example no connection to snapstore in ubuntu server, no updateserver etc.
Also have tryed fresh install of everything from zero but still doesnt work.
Its definitively only on TrueNas all other Network Clients work without problems (DHCP or static) and can ping whatever I want.
Does anyone have an idea whats the exact problem?
Thanks
